i need install help!!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 06-05-2014, 03:25 PM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
Default i need install help!!!!!
So I've been trying for 2 days now to install this kit. The directions are not much help and there not a single pic that I can find with this CURRENT design installed. My problem is the drivers side lower locator plate. I can't figure out how to bolt it on. The hole the bolt goes into is inaccessible from the bottom to put a wrench on it. I can barely fit my finger down there. I'm pretty handy with a wrench and I don't see how to bolt this up. If you have installed this latest design kit can you please post some pics of the drivers side along with explaining how you did it........ Thanks for any help
Old 06-05-2014, 03:32 PM
Vehicle: 2009
Rep:68
Red face
This is the lower locator plate
And this is the provided directions to mount the plate
Old 06-05-2014, 06:27 PM
Vehicle: 2009
Rep:68
Well I finally got the kit installed. I ended up taking a grinder to a 9/16 open end wrench and taking the thickness down to 3/16 and then removing material from the sides till I was able to get the wrench to fit into the small opening. I did use my own air line and fittings (Parker brand) and not the ones included with the kit. It's been aired up to 20lbs for about an hour now and no leaks. I drove around with 10lbs in the bags with no load on the truck and it drove fantastic. I think it handles bumps and potholes better than it did when stock. The biggest problem I had with the install was a lack of any photos. Here and on the web site all show the old style set up and not the new one that I received. I'm including a pass anger and driver side installed photo here for anyone in the future that my need it. The bags do slightly rub against the coils on both sides.
And John if you look at the pics and I installed anything wrong please let me know...
Drivers side
Passenger side
Old 06-06-2014, 02:24 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Looks OK Mike.
We'll take a look at the instructions again.
Enjoy the ride!
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
