Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-05-2014, 06:50 PM
TheDarkness03 TheDarkness03 is offline
Vehicle: 2014 Dodge Ram 1500
TheDarkness03 is on a distinguished road
Default How to race my Ram?
hey all, been drag racing for about 10 years now with various cars. Recently bought a 14' CC Express and taking it the track next week for a little fun, but i have no idea how to race this thing and get a good time slip, lol. Is it best to launch it in 4WD? take off the traction control? manually shift it?
truck is a 4x4 with a hemi, 6 spd, and 3.92's....bone stock. thanks!
Old 06-05-2014, 07:50 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Don't use 4wd. While my truck is an 05 without traction control, I'd bet you could leave traction control alone and play around with how fast you give her the gas. If the track does good prep, you can probably just nail it right off the line. My Ram has limited slip and launches pretty good, minimal spinning. On the street it will spin both tires for about 75 feet, but at the track, it hooks and goes. My friends with modded Cummins have to use 4WD, because of the massive torque. Use good fuel, try for only a quarter tank, I tune for 93 octane. Take everything out of your truck, tools, jack and spare tire. Perhaps pump front tires to max rated pressure, rears around 32psi should hook up nicely. If you want to really kick ass, a little 100 hp shot of nitrous, can make that 6,000 lb whale wake up. If you have "Tow/Haul mode, you might try a run with that engaged. I raised my shift points with a Diablo tuner to match my cam, 6200 rpms. If you dyno your truck and find peak power close to shift points, perhaps it might help to raise .
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
