Warped bed rail caps / tonneau cover - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 06-06-2014, 10:43 AM
schmidt schmidt is offline
Color: Maximum Steel Metallic
schmidt is on a distinguished road
Default Warped bed rail caps / tonneau cover
So my bed rail caps warped when it warmed up this spring. Took it to the dealership and they replaced both under warranty, 3 weeks later warped again. They're saying they may not replace them under warranty again because the warping is likely caused by my tonneau cover (Truxedo Lo Pro QT). They say that the warping is caused from the way the tonneau cover mounts to the rails of the truck. Anyone else have this problem?
Old 06-06-2014, 06:35 PM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
Yes but the metal of my bed is warped. I have learned that you only need to tighten the clamps just tight enough that the cover doesn't slide left and right.
I've tried to bend them back down with only slight success by standing on a 2x4 on the bed rail. Who would have thought the metal on the rail would be weak enough to bend by hand tightening the clamps? Not me.
S S H A D O W
Old 06-06-2014, 06:58 PM
Rep:2929
I have not figured out why the Gen 4 Rams bed rail under the rail cap is made so uneven
The Gen 3 & earlier bed rails were smooth, people only put rail caps on to protect the paint
Old 12-14-2015, 04:30 PM
DenTilly's Avatar
DenTilly DenTilly is offline
Vehicle: 2014 RAM 1500
Trim Level: Outdoorsman 4x4 CC
Color: True Blue Pearl
DenTilly is on a distinguished road
Just came back from my RAM dealer regarding the same issue; both bed rail caps are warped in the same area as the tonneau cover clamps [the center clamps on both the drive and passenger side]. The dealer gave me the same story that the warp was caused by the clamps.
This does not make sense to me, especially when seeing complaint regarding this issue on both this forum and the "RAM1500diesel" forum too, with several senior members reporting an on-going RAM problem since year 2009 with warped cap rails.
Can anyone summarize the current status of this discussion?
Old 12-14-2015, 05:56 PM
After the dealer replaced them they haven't warped again. That said, they don't sit nice and flat (wavy) like factory ford and gm caps. But that seems to be a thing with all Gen 4's.
I'm not sure why the caps warped in the first place. My guess it's just a faulty design on Ram's part.
Old 12-14-2015, 07:56 PM
Ramdandy Ramdandy is offline
Vehicle: 2014
Rep:65
Ramdandy will become famous soon enough
Aren`t all the tonneau covers today mounted with clamps. I have never had a problem or heard of a problem with warping rails. I personally don`t like the look of the rails, (kinda look cheap) would rather have steel exposed rails.
Old 12-24-2015, 03:33 PM
steveb's Avatar
steveb steveb is offline
Vehicle: 2015 RAM 3500 CC DRW
Trim Level: Tradesman
Rep:17
steveb is on a distinguished road
To stop the clamps from deforming the plastic I used some edging trim from McMaster Carr 8451A12. It clips on the pinch weld behind the plastic. It also protects the paint on the edge. The drivers side plastic is much shorter than the pass side on my truck.
SteveB
2015 RAM 3500 Tradesman CC Dually
Old 12-29-2015, 03:58 PM
iconic1 iconic1 is offline
Vehicle: 2013 1500 Hemi Crew
Color: Maroon
iconic1 is on a distinguished road
Any more detail? Ordered a tonneau yesterday and hope to install this weekend. Thanks.
2013 Ram 1500 Big Horn/Hemi/CC/4x4/Dk Red
Old 12-29-2015, 04:49 PM
ProDodge's Avatar
ProDodge ProDodge is offline
Vehicle: 2013 Dodge Ram Laramie
Trim Level: Laramie Longhorn
Rep:17
ProDodge is on a distinguished road
My cover is no where near the cap and mine stick up.
I call bs on this from the dealer...........
2013 Dodge Ram Laramie Longhorn LTD, 84 Dodge W350, 360 4 sp std cab
Old 12-29-2015, 05:38 PM
am3gross am3gross is offline
Vehicle: 2016 RAM BIGHORN 4X4
Trim Level: BIGHORN
Color: BRIGHT SILVER
am3gross is on a distinguished road
pictures anybody?
