Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Off Topic > Ask the Chef!
Ask the Chef! Have you ever wondered how to cook a steak like a pro? Ever wondered why restaurant food can be expensive? Why DOES everything taste better with bacon? Do you really need a dozen different knives to be a good cook? Have you ever wanted to ask a professional Chef a question? Well, now is your chance to ask a professional Chef any question you want.
Old 06-06-2014, 10:53 PM
jub jub's Avatar
jub jub jub jub is offline
Vehicle: 2014 Ram 1500 R/T
Trim Level: R/T
jub jub is on a distinguished road
Default Any good recipes for a good pork rub?
Inquiring minds want to know.
Old 06-06-2014, 11:37 PM
earlzach earlzach is offline
Trim Level: Big Horn Crew Cab
Color: Gray
Rep:13
earlzach is on a distinguished road
What are you putting it on? Pork wise?
Old 06-06-2014, 11:45 PM
Color: Gray
Rep:13
When I do pork baby backs I boil for 45 minutes meanwhile I fire up the coals and get the grill nice a hot.
When boiling be sure to ad two beef bulion cubes to give back where the boiling tried to strip. I use beef because I havent found pork cubes.
After boiling I rub a mixture of dark brown sugar and McCormics dry BBQ on both sides it will desolve a bit as you rub it into the hot slab.
Now out to the HOT coals. I start off on underside down to begin to seer or char the ends. about 5 minutes if coals are very hot. Then I turn on the back for a couple more. At this time I slather the underside with Sweet Baby Rays.
Turn after a couple minutes and slather the top with SBR's. Then turn it over to carmalize. A couple minutes and there DONE TO PERFECTION!!!!
Should only take and hour to do fall off the bone BBQ tenderloin cut Baby backs.
If your into a bitmore spicey add your favorite pepper sauce to the SBR's before slathering.
Old 07-11-2014, 10:36 AM
jub jub's Avatar
Trim Level: R/T
Ribs mostly. An occasional pork shoulder or butt.
Boiling ribs is a capital offense I hope you know! lol
I do my ribs on a smoker for about 5 hours or until the ribs reach an internal temp of 165. Low and slow! St Louis cut pork ribs with a good Memphis dry rub!
Old 07-11-2014, 12:42 PM
Aggie86 Aggie86 is offline
Vehicle: 2014 Ram R/T
Aggie86 is on a distinguished road
For ribs, I take a packet to a packet and a half of Adolph's Meat Marinade, add just a bit of water to make it into a paste and rub into both sides of the meat, especially near the bone. Then liberally apply garlic powder, "seasoned" pepper, seasonall, and onion powder. Wrap them twice in heavy duty aluminum foil. On a gas grill, on lowest heat setting, cook for 45 minutes on each side, then remove from foil and brown adding BBQ sauce if you like. The meat will fall off the bones. Very easy and delicious.
Old 07-13-2014, 12:50 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
ive made my own rubs hundreds of times...and they are good.
here is one recipe ive used quite a bit...
http://www.firecraft.com/product/kan...ub/bbq-recipes
Now, this is something you can buy...ive had it on pulled pork and it is amazing to say the least.
http://www.meatchurch.com/products/honey-hog-meat-rub
