Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 06-07-2014, 09:00 PM
1stDodge's Avatar
1stDodge 1stDodge is offline
Vehicle: 2014 Ram 1500 Lonestar
Trim Level: Lonestar
1stDodge is on a distinguished road
Default Push button start
Does anyone know if a push button start can be added to a keyed ignition?
14 1500 Lonestar QC Kicker's TonnoPro Black Mopar boards AVS vent visors AEM SOLO Mach40 5" tips
Old 06-07-2014, 09:45 PM
sportsguy's Avatar
sportsguy sportsguy is offline
Vehicle: '14 Ram CC 4x4 EcoD Laramie
sportsguy is on a distinguished road
Pretty much anything can be added, provide dyou're willing to buy all the new pieces needed and go throught he work of having the truck reprogrammed to "understand" the new button.
Keep in mind, though, that there could be a LOT of work here - depending on whether your keys have fobs, embedded chips, etc.
In theory, yeah, its doable because the factory installs these parts during assembly, but it's all the rest of the gear needed to make the "button system" integrate with the truck that might cause you excess cost and frustration.
...and now that I've said all that, someone will come along and explain how it's a plug and play item, I'm sure...
Old 06-07-2014, 09:56 PM
1stDodge's Avatar
I wonder if it's worth it?
Old 06-07-2014, 10:19 PM
sportsguy's Avatar
Entirely between you and your wallet, I think...
If it's my truck, I wouldn't bother retro fitting unless it's a largely plug and play situation. But that's me. I like things easy - if greasy.
Old 06-08-2014, 03:58 PM
1stDodge's Avatar
True, if there is a lot involved then probably not worth it..........I was just curious.
Old 06-09-2014, 12:22 PM
MikeDCop MikeDCop is offline
Vehicle: 2013 Ram 1500 Laramie
Rep:14
MikeDCop is on a distinguished road
Subscribed.
I'd like to know what's all involved and about what the cost would be. I have it on my Challenger and it is **** awesome!
Old 06-09-2014, 12:35 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
There are aftermarket options available as well. Here's one system that looks to be pretty good quality IMO. http://advancedkeys.com/Prod_AK104B.html
Old 06-09-2014, 01:47 PM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Key-less ignition (passive key) also includes, from the factory, passive entry. To get factory functionality, you would need to gut the truck and run a new wire harness that includes the support for antennas in the center, front doors, and rear cabin. The passive entry module is located on the rear cab wall, driver's side. I would also imagine several modules would need to be reprogrammed in order to support passive entry and passive start.
Might be easier to just replace the truck albeit that would be costly. I think passive entry/passive start should be standard, prevents over-loaded key rings.
Wow, I just looked over the installation manuals for both the passive entry and the passive start systems (Advanced Keys). That is an intense install and you are going to need the vehicle's schematic to find all the wires that have to be tapped. I also can't help to think about the error conditions and DTCs this system could trigger. The one thing that they didn't address in the users' manual is the steering column lock. Even if you install this, it looks to me like you would still need to turn the key the unlock the steering. Did I miss something? I was thinking about this system for my wife's car (2013 Equinox).
Old 06-09-2014, 04:50 PM
Jason2112's Avatar
Jason2112 Jason2112 is offline
Jason2112 is on a distinguished road
If it makes you feel better, the push button ignition and proximity sensors really aren't all that great. I mean, I can't count how many times I've hit the panic button on the key fob when it shifted in my pocket while getting in the truck. Who wants to look like a fool setting off their own alarm all the time? That would never happen if the keys were in the ignition where they belong!
Well, I tried.
Old 06-11-2014, 11:18 AM
Rep:14
Well, I tried.
I'm going to respectfully disagree on how great push button start and proximity sensors are. I have them on my Challenger and they are frickin' awesome!!!!!
I wish there was an easy way to put them on my Ram.
