Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 06-08-2014, 10:48 PM
Zr7cat's Avatar
Zr7cat Zr7cat is offline
Vehicle: 2014 Ram 1500
Zr7cat is on a distinguished road
Default Oil question?
What kind of oil have you guys been running in your Hemi's? I have been a Mobil 1 guy for a long time, but I see Chrysler recommends mopar or Penzoil. Anyone use the Penzoil ultra platinum synthetic 5w-20? Always had good luck with the Mobil 1.
Old 06-08-2014, 10:50 PM
2013Ram's Avatar
2013Ram 2013Ram is offline
Vehicle: 2014 Ram Sport
Trim Level: Sport 4X4
Rep:19
2013Ram is on a distinguished road
Mobil 1 but will likely switch over to the Pennzoil on the next oil change due to the Chrysler recommendation.
2014 Sport CC 4X4 Hemi; 5'7" Box; Leather; Remote Start and Security, Premium, and Convenience Groups; 3.92 LSD; Performance Hood; Air Susp.; Trailer Brake Controller; Class IV Receiver; ParkSense; 8.4AN NAV Radio; Spray-In Bedliner; Wheel to Wheel Side Steps. Other mods: DeeZee Tailgate Assist, BakFlip VP, Mopar Bed Extender, Cabin Fiilter, zXe foglight bulbs, 35W/5000K HID lowbeams, LED license plate bulbs.
Photos: http://www.ramforumz.com/album.php?albumid=3270
Old 06-08-2014, 10:52 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:717
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
also used mobil one since the mid eighties. found my hemi is a bit noisier when i used m1, so now i am using penzoil platinum.
Old 06-08-2014, 11:00 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Well of course Chrysler is going to recommend their brand (Mopar) and I suspect there may be some marketing/corporate agreement behind the Pennzoil recommendation, which is not to say there is anything wrong with Pennzoil. I see no reason why if you have used an oil for a long time, have been happy not to continue to us it, unless in doing so like Huntergreen, you find a performance issue. I started with Amsoil OEM and have switched to Amsoil Signature.
Old 06-09-2014, 10:09 PM
RangerGress RangerGress is offline
Color: Dark Red
Rep:16
RangerGress is on a distinguished road
The place to learn about oil is www.BobIsTheOilGuy.com (bitog) otherwise you just end up with a bunch of guys saying "my car likes <brand>" which are meaningless unless they've been doing oil analysis and tear downs.
Pennzoil Platinum is well respected, but you might go up one notch in viscosity. US OEMs generally spec oil a bit too thin because of CAFE standards.
Hard to go too wrong with Mobil1. It's not the best, but it's relatively inexpensive and the quality is ok.
Pick a couple oils that folks are talking about and so some searches on bitog. In a couple minutes you'll end up with a shortlist of good oils. OEM branded oils, like Mopar, is often quite good. Truth can change rapidly tho. Oil additive packages change often and w/o warning.
Old 06-09-2014, 10:12 PM
Vehicle: A Truck
Rep:2559
I agree with RangerGress and the link he provided is a good one.
Old 06-09-2014, 10:51 PM
RamSportsPower's Avatar
RamSportsPower RamSportsPower is offline
Vehicle: 2014 Ram 1500 cc
Trim Level: Sport Hemi 8speed CC
Color: Granite metallic
RamSportsPower is on a distinguished road
Pennzoil ultra platinum is a much pure oil. This is what I will use on my next oil change. I use quaker full synthetic and it runs pretty well.
Old 06-10-2014, 12:57 AM
RedRam5.7's Avatar
RedRam5.7 RedRam5.7 is offline
Vehicle: 2013 Dodge Ram
Rep:33
RedRam5.7 is on a distinguished road
I run castrol full synthetic 5w-20 in my hemi. Way I look at it for a truck as nice as our Rams I won't skimp on oil to save a few dollars.
Old 06-10-2014, 08:24 AM
revkev6 revkev6 is offline
Trim Level: Outdoorsman
Color: Deep Cherry Red
revkev6 is on a distinguished road
mopar oil is made by pennzoil hence the recommendation of one or the other.
my last truck (2005 f150) had a lifetime ford oilchange package. brought it into the dealer for every change with motorcraft oil and filter. by 60k she had a nasty top end tick....
my father still has his 2004 f150 with the same engine. he has been putting heavier oil and an extra quart in at every change. his motor is quiet as the day he got it....
Old 06-10-2014, 08:49 AM
boatbum boatbum is offline
Vehicle: 2014 Ram Larmie
boatbum is on a distinguished road
That was probably a design issue as much as anything. I had an 07 Expedition with the 3v 5.4. Used whatever bulk oil at my local service station for 7 years and 130k miles. Never a tick, and never used a drop of oil. Pre-07 5.4 3v's where known to have bad cam phasers and they'd chatter.
I don't worry about oil much anymore. I bought the oil change package from my dealer. Basically $18/oil change. I'll bet the rest of the truck will fall apart long before the Hemi dies from not using a top shelf oil. I won't keep it much past 100k anyway.
I've used various synthetics in the past, I've just never noticed a difference to warrant the change and I've never tried to get the last mile out of my vehicles, I usually get tired of them long before they wear out.
I do use synthetic in my boat, but that's what the engine manufacture recommends and it only get's changed once a year.
But yeah, oil is not that expensive, so if it makes you feel better....
