Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
tonneaucovered.com
Old 06-09-2014, 11:39 AM
dhrren dhrren is offline
Vehicle: 2016 RAM 1500
Trim Level: Limited
Color: Maximum Steel
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
dhrren is on a distinguished road
Default I ruined a fender flare on my new 2014 Laramie, HELP
Good Morning,
Well I bought my 2014 Laramie QC 4x4 just a little over 2 weeks ago and when I was pulling out of my underground parking I cut it too sharp and bam the fender flare is beyond buffing. I am such a cautous driver but hey we all make mistakes. Literally chunks came out. Thank goodness it didn't hit the body of my new ram. I am sick to my stomach.
Question: Can anyone help me find a place to order just 1 painted (Bright Silver) Laramie Fender flare? Or should I just call my local dealer?
Thanks in advance,
Darren
Old 06-09-2014, 11:48 AM
Monsoon Chopper's Avatar
Monsoon Chopper Monsoon Chopper is offline
Vehicle: 2013 Ram QC 1500 Laramie 4x4
Color: Bright White/Silver
Rep:67
Monsoon Chopper will become famous soon enough
Call the dealer, get the right part number, then see if you can find it online less expensive.
Old 06-09-2014, 03:36 PM
Trim Level: Limited
Thanks for the insight. I checked online and then at the dealer. The flares have to be painted. $150 for painting and $224 for the flare. I wonder if a body should could repair the flare? My other half says no because it is plastic. I am attaching some pictures of the damage.
Old 06-09-2014, 04:41 PM
Jason2112's Avatar
Jason2112 Jason2112 is offline
Vehicle: 2014 Ram 1500
Jason2112 is on a distinguished road
Ouch, that's too bad. I'm no body shop expert but I've always been told that it's easier to replace soft plastic pieces than to attempt to repair them.
Old 06-09-2014, 05:39 PM
Keebee's Avatar
Keebee Keebee is offline
Trim Level: Longhorn
Color: Black gold pearl
Keebee is on a distinguished road
You could take them all off until the new one is ordered or it comes in.
Ordered 2/15, Delivered 4/24, Coolant leak 4/26 turned out to be an O ring.
2014 Ram 1500 Lonestar Ecodiesel 4x4 black gold pearl
Old 06-09-2014, 05:45 PM
hemi4452's Avatar
hemi4452 hemi4452 is offline
Vehicle: 2013 ram crew cab sport
Trim Level: sport
Color: True blue pearl
Rep:77
hemi4452 will become famous soon enough
I had them put on my sport. He bought each on seperate. Which fender is it. I have the part numbers on the receipt
Old 06-09-2014, 05:51 PM
hemi4452's Avatar
Trim Level: sport
Rep:77
Rt front 1td26tzzac $175
lt front 1td27tzzac $175
rt rear 1td44tzzaa $220
lt rear 1td45tzzaa $220
Old 06-09-2014, 06:27 PM
Guls Guls is offline
Vehicle: 2014 Dodge Ram Bighorn
Trim Level: Bighorn
Rep:14
Guls is on a distinguished road
I had an issue with rear and front bumper of my Mercedes and a body shop took care of it.
Old 06-09-2014, 08:36 PM
Ranman's Avatar
Ranman Ranman is offline
Vehicle: 2016 Ram 1500
Rep:120
Ranman will become famous soon enoughRanman will become famous soon enough
Well I have seen worse. Seeing as you are willing to replace, I would go ahead and sand it down and see how it looks? start with 800 grit wet sand.
worth a try.
Old 06-09-2014, 10:24 PM
Kamine Kamine is offline
Trim Level: Bighorn
Kamine is on a distinguished road
Experienced body tech here:
Don't bother having that flare repaired. It's definitely repairable, but NOT on a brand new truck, especially when a new flare is so cheap (remember that body labor runs $80+ per hour and would probably be 2 hours in the repair, plus paint labor).
On an older vehicle, sure. There are plenty of good products out there for plastic repair, however over time there is a chance of the filler shrinking or warping.
Find a reputable local shop and they can most likely match the flare better and at a lower cost than the dealership.
