Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 06-11-2014, 09:06 PM
hotrod1090 hotrod1090 is offline
Vehicle: 2012
Color: Charcoal Gray
hotrod1090 is on a distinguished road
Default Installing a brake controller on a 2012 Ram
I have a 2012 Ram that was built in Oct. I am trying to install a brake controller that I had in my 2009, but the connection isn't the same on my 2012. I can't find anyone at the Dodge Service Dept. to tell me what I need to do. The controller that I have is made by Draw-Tite. It's the Activator II model #5500. I found a video on YouTube that shows the 2013 having two connectors. One attaches to a square connector that's located under the dash where your right knee is. The other connector is a single port that's located close to the brake pedal where the wire for the brake switch and the wire for the throttle sensor join. I was told that Dodge changed the way brake controller is connected starting with models built in late 2012 and into 2013. I think the Proportional Wiring Adapter I need is part #3023-P.
Can anyone tell me if this is correct? Has anyone else experienced this problem?
Old 06-12-2014, 12:22 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
I have a few questions.. first you have a 2012 truck, and a wiring harness for a 2009 and yet you are posting in a 1994-2001 (2nd Gen) forum.
Secondly, where did you get your part number for your wiring adapter?
I found the partnumber by TowReady (same company that makes the Activator II #5500) to be 22293. This adapter plugs directly into your factory wiring harness under the left side of the dash. INSTALLATION MANUAL
Dodge lied to you 2011-2012 are the same harness, and 2013-2014 are the same harness. So depending on Date of Manufacture, you might need a 2013 Harness.
I hope this helped out some.
