Old 06-11-2014, 09:35 PM
red2k2timmy red2k2timmy is offline
Vehicle: 2014 5.7 cc
Trim Level: big horn
Color: gun metal
red2k2timmy is on a distinguished road
Default 2014 1500 regearing
I just picked up my first ever gas ram and was told from the dealer the 3.21 gears are plenty for what I needed well the guy was a d bag and lied to me about alot of things now I feel my trucks lacking alot trying to pull my 8400 gvw camper is there any way to regear the new trucks or am I sol right now
Old 06-12-2014, 01:28 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
I'm assuming your truck is 4wd. You can do it... But it isn't cheap unless you find someone with 3.92's to swap with you.
Old 06-12-2014, 04:54 PM
Color: gun metal
Im not expecting it to be cheap but I would at least like to be able to find gears some where or something on the topic
Old 06-12-2014, 05:15 PM
Rep:2051
In order to swap gears in the front you need a front diff from a 2011 Ram 1500 since you cannot change gears in a 2012 and up (the gears are welded to the carrier). Depending on the gear setup you go with you may need to do some machining on the carriers as well. The guy to talk to about this is Andrew at Bully's Performance. He put 4.56's in his 2012 plus he can get you Yukon gears if you do want to go aftermarket. Send him an email at andrew@bullysperformance.com.
Old 06-12-2014, 07:11 PM
Color: gun metal
Really they have the ring and pinion welded into the front axle thats kind of a *** move . Ill message him im wondering if its a strait bolt up for a 12 ifs . Ill ask him about the gears to but they already sponsor my rock crawler crew
Old 06-20-2014, 10:43 AM
trojjan trojjan is offline
Vehicle: 2012 Ram 2500 Longhorn
Trim Level: Long Horn and RT
Engine: 2011-2012 409ci (6.7L) Cummins Turbo Diesel 350hp 800lb/ft
trojjan is on a distinguished road
Default ratio
My 2012 has 4:10's and it will pull anything.
Old 07-14-2014, 10:00 PM
skaling's Avatar
skaling skaling is offline
Vehicle: 2014 1500 Crewcab
Rep:18
skaling is on a distinguished road
Never trust a car salesman.. But in his defence, you should have done some research before you bought knowing that you needed to tow a 8400lbs camper.
2014 Ram Sport 4x4 CC short box. 5.7 Hemi, 3.21. Firestone 1000 lbs airbags.
Old 07-17-2014, 08:08 AM
DustinT DustinT is offline
Vehicle: 15 Laramie CC Ecodiesel 4x4
Color: Blue Streak Pearl
Rep:18
DustinT is on a distinguished road
Do I even need to post that any of these modifications will void your warranty? Well, why not.
http://www.pro-blog.com
Old 07-17-2014, 12:06 PM
Rep:2051
No single mod can void the warranty on your entire truck. Warranty can only be voided if the mod is the cause of the problem with the truck. So explain to me how changing gears to a lower ratio is going to cause a problem?
Old 07-17-2014, 01:20 PM
Rep:18
Well, you'd certainly immediately lose the warranty on the differential and if you had to change the transfer case you'd lose the warranty on that as well. Then, we have to start to talk about how this change would impact the transmission and the control systems for the engine, transmission and transfer case. Realistically speaking, maybe swapping the differential won't make a bit of difference but there's no way to know until you try it. That's an expensive gamble. ANY dealership that wanted to could easily use this as an excuse to not repair pretty much anything in the drivetrain they felt like.
There's no way I'd jeopardize a 100,000 mile powertrain warranty on a $30-$40k truck for this. I bet the OP would be better off to sell his truck and just go buy a new one now that he's learned what he really needs. There's much less risk in this approach and in the long term, I can tell you which one I'd put my trust in.
