Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 06-12-2014, 11:29 AM
atknut atknut is offline
Vehicle: 2004 Dodge Ram
atknut is on a distinguished road
Default Towing in low range
No, not down the highway.
But, I want to use low range on my 97 1500 4x4 5 speed for backing up and "fine tuning" the trailer. The question is, has anyone ever put a vacuum valve on the center axle disconnect? I want low range, but not 4 wheel drive. It seems like I could just run a couple of vacuum lines and an electric valve somewhere.
Thanks.
Old 06-12-2014, 02:04 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Just put it in 4x4 Low, you'll be fine if you don't make any drastic turns, or better do it on grass or dirt. I use my Ram to skid out logs. It pulls hard enough to break 15,000 lb dacron tow rope, never did any harm.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 215,000 miles To Hell and back. 14.2/96 mph NEDW
Old 06-12-2014, 08:41 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I had an S/10 that had vacuum problems. I wound up going to the pet store and buying a valve for a fish tank and hiding it under the dash.
I would open it to engage the 4wd and close it to shut it off.
