No fan/ No air or heat - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 06-22-2014, 02:34 PM
DTPrice DTPrice is offline
Vehicle: 2006 Dodge Ram 3500
DTPrice is on a distinguished road
Angry No fan/ No air or heat
Hi out there. I have a on going problem with a 06 3500. The fan has a mind of it's own and it will die. No fan. Year ago it was at the dealership for same problem. They replaced the hole fuse panel under the hood and new air condition and lines and some other things. It cost a plenty with the extra warranty . Now the problem is back and no warranty.
Hope that someone can help.
Old 06-22-2014, 03:58 PM
earlzach earlzach is offline
Vehicle: 2014 Ram 1500
Trim Level: Big Horn Crew Cab
Color: Gray
Rep:81
earlzach will become famous soon enough
Have you noticed if your air seems to be ok running down the highway but at Idle there is nothing? Is so its your condenser fan. Its only about 80 to 100.00 and takes about 20 to thirty minutes to change.
Old 06-22-2014, 04:49 PM
Thank you, the fan/air works great at any speed when it works.
Old 06-22-2014, 06:20 PM
Rep:2962
Type into your computer Search engine
HeaterTreater Dodge for your Climate Control issues
Then settle back with your beverage of choice & start watching the videos
Made by HeaterTreater & everyone else
For the engine fan
I would look at the YouTube videos made by Eric the Car Guy
Good Luck
Old 06-22-2014, 07:22 PM
jawzs2's Avatar
jawzs2 jawzs2 is offline
Trim Level: SLT BigHorn
jawzs2 is on a distinguished road
Is it intermittent, sometimes works? A bad\worn ignition switch could also be the culprit, have seen the same issue on a couple of these, turned out to be the ignition switch. Check for +12 at the blower motor w/key on, if no power most likely a bad ignition switch. if good, check for motor ground, no ground is probably a bad blower resistor, sorry, I don't remember what the wire colors are, A.G.E is setting in.
Old 06-23-2014, 08:46 PM
Thank you and I will check it out.
Old 06-23-2014, 10:04 PM
unlisted's Avatar
unlisted unlisted is offline
Rep:16
unlisted is on a distinguished road
Dependent on the mileage (and time) since you had it fixed the parts they replaced may still have a parts warranty left.
Old 09-04-2014, 01:17 AM
BigHossKA BigHossKA is offline
Vehicle: 2003 Dodge Ram
Color: Blue
BigHossKA is on a distinguished road
did you ever get the problem fixed??
