Old 02-19-2014, 10:40 PM
Cale Cale is offline
Vehicle: 2006 Dodge Ram 5.7 4x4 MegaCab
Cale is on a distinguished road
Default Steering pops
Admin, not really sure where to put this.
I've been getting a popping out of my steering, usually at full left while turning, bu it'll do it going back right again also. Just replaced tie rods and hubs. I can't feel the pop in the steering wheel.
Old 02-22-2014, 08:06 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
is it while you are moving? Do you have a solid front axle or IFS? a lot of times a bad cv joint will make a popping/clicking noise while turning. Do you have any torn boots?
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 03-04-2014, 11:23 AM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:15
bparsel is on a distinguished road
Bumping this.
I have the exact same issue going on. When steering wheel is turned full left and rolling slowly will get a LOUD POP of metal on metal. Truck has new tie rods, control arms, struts, and ball joints on it last summer.
Its been too cold to try and get a video or get my wife out there to do it while I look under the truck...and she'll probably just run me over anyways!!!
I'm going to try and get it on a lift and see if I can recreate in the shop. Its driving me nuts though and I cant see any visual areas of metal on metal wear.
The POP is loud enough that people on the street and in parking lots have turned and looked at me when it happens......its LOUD.
Old 03-04-2014, 05:58 PM
Like I said mine was just a bolt that wasn't properly torqued. And it needed to be TIGHT
Old 03-04-2014, 07:44 PM
AFMEDIC's Avatar
Color: Maroon
Rep:18
Which bolt was it
Old 03-04-2014, 11:59 PM
Bolt is under the driver side about in line with the steering wheel. Bolt pushes through the front and has a nut on the back. It's the bar that keeps the front axle centered under the truck.
Old 06-24-2014, 12:14 AM
cvgennep cvgennep is offline
Vehicle: 2004 Dodge Ram 1500
Color: Maroon
cvgennep is on a distinguished road
I have the same problem after I lifted my truck. I'll have to check the bolts under there! Thanks
Old 06-24-2014, 12:31 AM
It didn't talk much to tighten it, bout a quarter turn but made all the difference
