Old 06-23-2014, 10:23 PM
2011redrt 2011redrt is offline
Vehicle: 2014 RT
Trim Level: RT
Rep:25
2011redrt is on a distinguished road
Default 2014 Lower 2-4
Anyone lower a 2014 RT? I lowered my 2011 RT and 2012 crew. Looked under my 14 and noticed aluminum lower control arms. I didn't know if this was an issue or not.
Old 06-24-2014, 09:17 AM
chrisb38002's Avatar
chrisb38002 chrisb38002 is offline
Vehicle: 2013 Dodge Ram
Trim Level: R/T
Rep:86
chrisb38002 will become famous soon enough
Not an issue, my 13 has the same aluminum control arms. I have the McGaughy deluxe kit which has the lower front spindles. McG has cut a section in the spindle to clear the larger ball joint area, just have to make sure you order the kit for 13-14 models. Mine went in without a problem.
Also there are several members here using the spring kits like BellTech and McG without issues with the new arms.
2013 White Ram R/T
Mods: BT Catch Can (red), Mufflex DOD24, S&B CAI, BakFlip VP Tonneau, McGaughy's 2/4 Deluxe, Spohn Adjustable Panhard, AirLift 1000, Hellwig Rear SB.
Old 06-24-2014, 10:38 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
+1 to Chris. I have seen his RT in person and the lower looks amazing!
Old 06-24-2014, 02:29 PM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
Thanks guys. I know kit choice is quite the topic on here but I have used BT for years with no issues on Che@&, Fo$& and Dodge. Thanks again.
Old 06-24-2014, 02:34 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Let us know if you are interested in forum member pricing!
Old 06-24-2014, 04:16 PM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:15
Hemi HFE is on a distinguished road
afaik all 13+ 2WD 1500 (including R/T) use the same lower control arm
04877198AB or 04877199AB for L & r side, see e.g.
http://www.mopar.com/part/04877199AB...=2542185&b=ram
looks similar to the '12 ? was the '09-12 steel ?
http://www.mopar.com/part/68037501AC...=2520012&b=ram
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
Old 06-24-2014, 05:25 PM
Trim Level: R/T
Rep:86
Believe they did, the ball joint area on the 13-14 arms is larger than previous years. If you try to install lowering spindles from an earlier kit, they will interfere.
2013 White Ram R/T
Old 06-24-2014, 09:40 PM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
I found a complete BT kit for $472 with free shipping. Where is the forum discount through?
Old 06-24-2014, 10:21 PM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
What is the part number for the air lift 1000? I bought it for my crew and I think it was listed for a 2011 Durango.
Old 06-25-2014, 12:03 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
The forum discount is through us, Bully's Performance! I will PM you the pricing!
