Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 06-25-2014, 02:42 AM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2008 Reg. Cab/Bed 4x4
Rep:70
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
Post '06-'08 1500 Non-Mega Cab Moog Suspension Part #'s
These are the parts numbers from Bumper to Bumper Auto Parts and should fit all 1500s except mega cabs.
Upper Ball Joint-------------------K100115
Lower Ball Joint-------------------K7411
Outside Tie Rod Ends--------------ES80574
Sway Bar Link---------------------K80894
I was also told that it wouldn't hurt to put rubber shims behind my sway bar since I had over 100K miles on my truck.
Tomorrow when I have some light I'll also put up some parts numbers for shocks on the front.
K&N Cold Air Intake, Magnaflow Exhaust, Rancho RS5000s, TRUXXX Leveling Kit, Heavy Duty Towing Shackles, Recon Smoked Cab Lights, Chrome Fender Flares, Stainless Door-sills, Chrome Door Trim, Atturo Trail Blade 35x12.50R20, METAL Grille Inserts.
Old 06-25-2014, 10:39 PM
Rep:70
For anyone interested I also collected a few shock numbers for quick reference.
Rancho RS5000---------(front)RS5788 and (rear)RS5274
Bilstein HD--------------(front)BE5-E301-H0/24-186261 (rear)BE5-2550-H1/24-025508
Bilstein 5100------------(front)BE5-E523-H0/24-186988 (rear)BE5-6682-H8/24-185783
For those interested in significantly increasing your 1/2T truck's capacity the Monroe Load Leveling shock with coil spring assist can increase capacity up to 1100lbs according to Monroe. The part number on the body of mine was P095D.
Those are the proper numbers off the websites. That said the bodies of my old HDs had 31910 1E30H0 on them FWIW. I'll check again when it gets brighter outside
Old 08-13-2014, 12:41 PM
galeener galeener is offline
Vehicle: 2006 ram
galeener is on a distinguished road
Thanks for the info.
Old 09-05-2014, 12:55 AM
Rep:70
Moog Front Sway Bar Bushings----K7383
From personal experience I have just found out that if you need ball joints or sway bar links you need to change the sway bar bushings. Mine looked fine till I pull the bar out of curiosity and they were starting to break down. To make it more interesting the material had almost worn all the way through on the back side.
3rd gen ram, bilstein 5100 shocks, bilstein hds, moog part numbers, rancho rs5000s
