Old 06-29-2014, 12:59 AM
sdvratrod sdvratrod is offline
Vehicle: 07 ram 3500
sdvratrod is on a distinguished road
Default need help with identifying a engine harness wire on a 5.7L
ive done a 4.7 to 5.7 hemi swap in my 09 ram. my truck is a 2wd but the 5.7 hemi engine/harness and ecu were out of a 4wd 2012. the only issue ive ran into is the harness plug on the passenger side going into the firewall, the 4wd has a large 4 row plug and the 2wd has a 2 row smaller plug so ive had to cut the 4wd engine harness plug and solder up the 2wd plug i had 14 wires left after i soldered up all the wires used on the smaller plug. ive traced out the wires and found all but 5 went to transfercase plug. figured out the 4 other wires and the only one i have left that i cannot figure out what it is for is a pink with grey stripe, ive traced it out and it goes to the big engine harness plug thats beside the fuse box.
with all that being said what is the wire for and do i need it?
I traced the pink/grey wire out on my 4.7 2wd engine harness from that same plug that goes by the fuse box and it goes straight to the black pcm connector.
if anyone can shed some light on this i would greatly appreciate it
Old 07-02-2014, 12:14 PM
Anyone?
