Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-01-2014, 04:49 PM
hemiwk57 hemiwk57 is offline
Vehicle: 2002 Dodge Ram 4.7 4x4
hemiwk57 is on a distinguished road
Default How to: Replace Lower Control Arm
I need to replace this on my truck, and looking for some instructions. Can anyone help me out?
Old 07-03-2014, 01:53 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
Does you 02 have the torsion bar front end on it? if it does you will have to remove the torsion bar which requires a special tool or redneck engineering and a c-clamp, but that is dangerous so be careful, once you get the hub/spindle off you just need to remove the tierod then there will be a bolt on the front side of the control arm as well as a bolt that will be visible once you drop the torsion bar after removing those to bolts with should drop right off.
