Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 07-03-2014, 11:14 PM
mavagrand mavagrand is offline
Vehicle: 2013 ram
Trim Level: Tradesman
Color: Bright Pearl Coat cherry
Rep:13
mavagrand is on a distinguished road
Default Starcraft Autumn Ridge 26RLS
Wife and I are looking at buying this as an upgrade from our current TT. Our truck is a 2013 Ram 1500 CC with the 5.7 Hemi and the 3.55 6 speed tranny. Trailer weighs 6130 and has a tongue weight of around 640 lbs. It is 30 foot long from back bumper to tongue. My truck has a tow capacity of 8800 lbs and a cargo capacity of 1500 lbs. I think I'm well within the weights, just wonder about the length. don't wanna do the white knuckle drive. what do you guys think? will this trailer/TV combo be good?
Here's a link: http://www.starcraftrv.com/select-tr...floorplan-main
Old 07-04-2014, 12:23 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express 4X4
Rep:308
The GVWR is 8250 and your truck is 8800? After you and the wife you have a couple of hundred pounds left over. Water alone will cover that. It's a great looking trailer design but I think it's just a bit too much for your truck.
333Half the beast
I used to be
Old 07-06-2014, 12:20 AM
Philpaint Philpaint is offline
Vehicle: 2014 RAM 1500 4X4
Rep:16
Philpaint is on a distinguished road
I have a 34 foot TT and no white knuckle!
The RAM pulls great! It's so powerful. I do have the 3.92, but I think you'll be alright with your truck
Old 07-06-2014, 01:48 PM
h2oman's Avatar
Rep:308
Yes the motor is more than up to the task. That is not issue. The issue is the towing capacity of the truck.
333Half the beast
I used to be
Old 07-07-2014, 09:31 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
I've got a Dutchmen 261BHS, dry weight is 6873lbs, loaded scale verified 7200-7300lbs Axle weight ready for 2 weeks with 4 peoples. it's 33' tip to tale and I have a few hundred lbs left on my payload.tongue weight is 850-875 depending on if the Fresh tank is full. Bed of truck is always emptyand everythingwe need goes in thetrailer.
I have air lift airbags and ablue ox sway pro 1200lb hitch. The truck works and if I had 3.92s it would be ideal, but it gets me there without white knuckling
Old 07-18-2014, 01:51 PM
Vehicle: 2013 ram
Rep:13
This is almost identical to my situation and exactly how I plan on handling it, although I don't have airbags, hoping the WDH will take of sag/sway issues. If I need airbags, what do you recommend and how much would they be?
Old 07-18-2014, 03:33 PM
h2oman's Avatar
Rep:308
Airlift 1000's are $87 delivered from Amazon Prime. That said, the WD hitch will take out all of your sag if you do it properly.
333Half the beast
I used to be
Old 07-18-2014, 09:05 PM
Vehicle: 2013 ram
Rep:13
Are they easily installed?
Old 07-18-2014, 11:21 PM
h2oman's Avatar
Rep:308
If you use a jack and get your rear wheels off the ground it is pretty easy to get the bladders inside the coils. If you leave the wheels on the ground it is a bitch. Trust me I know. Then decide if you want an individual line to each bladder or use the T. If you want to see a war break out ask if you should use the T or not.
333Half the beast
I used to be
Old 07-23-2014, 01:07 PM
jwhitney41 jwhitney41 is offline
Vehicle: 2014 Ram 2500 4x4
jwhitney41 is on a distinguished road
I have a Eclipse Evolution TT with a dry weight of 5200 pounds. I suspect, with everything I have on it, it is getting close to it's GVWR of 7000lbs. I also carry about 750lbs in the back. Keep in mind that my truck is a 2014 2500 4x4 with the 5.7L. It is so under powered I had to purchase a Diablo Sport tuner to ad additional HP and TQ. Haven't towed yet with it tuned but we shall see in a couple of weeks. Maybe I am used to my other truck with the 5.9L Cummins. It had now problems towing the trailer with that. I know, I know, should have stayed with the Cummins........
Anybody having problems with towing with a Hemi?
