Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 07-05-2014, 07:57 PM
Kevin2014 Kevin2014 is offline
Vehicle: 2007 RAM 1500 4X4
Color: Stone Grey
Kevin2014 is on a distinguished road
Default Smelling coolant after engine is turned off
I have a 07 Ram 4X4 it smells like coolant after running for a while but I don't see any drips or puddles on the ground. I have checked all the hoses they appear to be okay, looking at the front of the radiator I see only a shiny spot near the top but no coolant visible I have not seen coolant level drop either need help.
Old 07-05-2014, 08:40 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Mine was doing that, I eventually found a tiny leak at the thermostat housing. The gaskets on thermostats are kind of cheap.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 07-09-2014, 11:38 AM
iveyusmc iveyusmc is offline
Vehicle: 2006 Ram 1500
Trim Level: Texas Edition
Rep:12
iveyusmc is on a distinguished road
check your pass side floor board for any dampness for a failing heater core.
Old 07-16-2014, 07:41 PM
Ramhahdah Ramhahdah is offline
Vehicle: 2002 Dodge Ram
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Ramhahdah is on a distinguished road
Are you smelling it inside or outside? As far as the spot you're seeing run a rag over it to see if it's antifreeze or something else.
