Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 07-05-2014, 09:43 PM
Jstin's Avatar
Jstin Jstin is offline
Vehicle: 2011 RAM 1500 4x4 Sport 5.7
Jstin is on a distinguished road
Default Stumbles out of the hole.
33,000 miles on my 2011 Sport. I run 89 octane from BP religiously. Just got it late last summer. I did the plugs at 32,000. OEM NGK's gapped. I drive fairly aggressively probably compared to some. Not a dangerous hotrod by any means but I don't putz. I live in a subdivision that doesn't have a controlled intersection to get out on a 45 mph road & if I see an opening I take it.
My Q is: my truck stumbles pretty badly from a stop. I haven't looked at the tach so I can't give any RPM's. I probably should have that info before posting this. Once I get straightened out of my turn for 20-30 feet or so it pulls like crazy. My next mod will be a throttle body, probably an 87mm from Moes. Will the TB fix the stumbling? I've turned off the TC & still get it. Not that I'm lighting up my pita stock wranglers that will be replaced soon.
2011 RAM 1500 Sport 4x4 5.7 3:55 Gears, 18" Magnaflow, Drop in K&N filter, BT CC, TonnoPro Lo-Roll, front tow hooks, cabin filter, Moes 85mm TB, Homemade CAI, Bilstein leveled 2.1", tailgate assist. AVS in channel visors, Magnaflow Y pipe, DiabloSport DCX inTune I-1000, HF tune
Old 07-06-2014, 01:10 AM
dac1959's Avatar
dac1959 dac1959 is offline
Vehicle: 2012 Ram 1500
Trim Level: ST Express
Color: Dark Cherry
Rep:35
dac1959 is on a distinguished road
Torque management.
2012 Express cc 3.92 lsd
Old 07-14-2014, 05:01 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:736
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
x2 on the TM, and no the throttle body will not eliminate this "stumble" nor will it do any else except become a paper weight. do a search before you buy.
Old 07-16-2014, 10:45 PM
Jstin's Avatar
Can either of you explain torque management please? Is that something done with ones right foot?
I done a search on throttle bodies and see a lot of comments like, "huge difference in throttle response." That's what I'm looking for. I need to find where this lag is coming from somehow.
Old 07-18-2014, 07:40 PM
Rep:736
TM is a computer controlled nanny to force us to to go easy on our transmission and prevent us from hard quick rabbit starts. that is how they can give a 100,000 mile drivetrain warranty.
Old 07-18-2014, 10:01 PM
Jstin's Avatar
Hmm, Thank you, I wasn't aware of that. So where's the switch to turn that off? I hope that's what it is and not an issue with my truck. Like I said, I'm not flooring it, seems very restrictive by RAM but I can see how it would make the warranty work for them.
Does a good tuner have the capability to bypass the TM?
