Old 07-07-2014, 10:21 AM
lewisb13 lewisb13 is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Rep:19
lewisb13 is on a distinguished road
Default Service 4WD/Traction Control/ABS Lights are ALL ON
Has anyone had this issue? Im assuming this is a wheel speed sendsor. It blows because you cant use cruise control when all these lights are on.
Old 07-07-2014, 10:28 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Assuming you have already checked the functions of those elements, I would try resetting the computer and see if that solves the issue. If not I would call for service to check it out.
Old 07-07-2014, 02:40 PM
Rep:19
Just pull the battery cables for 20 mins right?
Old 07-07-2014, 04:28 PM
Chris In Marshfield's Avatar
Chris In Marshfield Chris In Marshfield is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Hunter Green Pearl
Rep:34
Chris In Marshfield is on a distinguished road
I had the exact same problem earlier this year. A wire to the right rear wheel speed sensor broke. I suspect a similar problem for you.
http://ramforumz.com/showthread.php?t=161638
~Chris
Old 07-07-2014, 04:41 PM
Vehicle: A Truck
Rep:2559
Yes at least 20 minutes.
Old 11-23-2014, 08:12 PM
Josh0526 Josh0526 is offline
Vehicle: 2011 Ram Outdoorsman
Color: Green
Josh0526 is on a distinguished road
Mine did the same thing and it was an abs sensor on the wheel.
