Old 07-07-2014, 02:38 PM
spnich1x's Avatar
spnich1x spnich1x is offline
Vehicle: 2011 1500 SLT Quad Cab
spnich1x is on a distinguished road
Default Stupid Question of the day
I have a 2wd 1500. Do the wheel bearings need to be repacked? I can't find anything on 2wd.
I am planning to upgrade the brakes in the near future and if this needs to be done I will do while I have everything off.
Thank you for your time.
Old 07-07-2014, 08:26 PM
Saltillo Express's Avatar
Saltillo Express Saltillo Express is offline
Vehicle: 2013 Ram Express
Saltillo Express is on a distinguished road
Generally you try and move the wheels top to bottom, front to back (not spinning) once the truck is jacked up. If they have any slop in them , movement, whatever - then you have issues. Some bearings are serviceable. Others are not. Depends on the year.
Chance
Old 07-09-2014, 12:47 PM
spnich1x's Avatar
Thanks for the info. I will check it out.
Old 07-13-2014, 12:02 AM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
The front bearings on my '09 2wd are sealed, lubed for life, pressed in units, not serviceable. There should be no change in yours.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 07-13-2014, 07:25 PM
bigreid's Avatar
bigreid bigreid is offline
Vehicle: 2011 Ram
Rep:23
bigreid is on a distinguished road
the newer trucks usually have the hub as a whole replaced. They usually even include the wheel speed sensor
Project Diamondback
Old 07-13-2014, 11:43 PM
spnich1x's Avatar
Cool thanks for the info. I will be pulling the wheels to look at the brakes in a couple of weeks.
Old 07-14-2014, 05:36 PM
Trim Level: sport
Color: green
Rep:643
what break upgrade are you doing?
Old 07-14-2014, 07:38 PM
spnich1x's Avatar
Nothing major, just slotted rotors and new pads. I am going to get new wheels, but I am staying with 17's so I think the stock calipers would be good. Looking at painting those at the same time.
Old 07-18-2014, 08:42 PM
Trim Level: sport
Color: green
Rep:643
tks spinich.
