Old 07-09-2014, 01:45 AM
kev12345 kev12345 is offline
Trim Level: Sport 4x4
Rep:14
kev12345 is on a distinguished road
Default Popped ball joints with bilsteins
Since a lot of guys here have levelled with bilsteins on their 2013+ trucks! I'm curious if anyone has had ball joint issues. I was warned by my mechanic that the crappy control arms on these trucks don't fair we'll with level kits. I looked around the forum and found only those with block style level kits are having the popped ball joint issue. Anyone with bilsteins on a '13+ truck want to chime in about long term use? Is this a conspiracy to sell zone uca's? Lol
Old 07-09-2014, 02:24 AM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2008 Reg. Cab/Bed 4x4
Rep:70
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
I have an 08 and am in the midst of replacing ALL of mine from my Bilstein level...or failure, I don't know which. The front end of the '09 forward body style has smaller control arms still so I can only imagine that they are still more likely to be short lived.
Luke
K&N Cold Air Intake, Magnaflow Exhaust, Rancho RS5000s, TRUXXX Leveling Kit, Heavy Duty Towing Shackles, Recon Smoked Cab Lights, Chrome Fender Flares, Stainless Door-sills, Chrome Door Trim, Atturo Trail Blade 35x12.50R20, METAL Grille Inserts.
Old 07-09-2014, 02:26 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I haven't heard of anyone popping ball joints with a Bilstein level. And no issues whatsoever on a 06-13 regarding ball joints.
Old 07-09-2014, 08:12 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
I truly doubt that as many people installing a level kit nowadays will ever experience this ball joint popping unless, the installation and torque procedure was performed incorrectly, or, the truck is being used in extreme off-roading practices. All of which, the improving or beefing up of control arms and other suspension parts should be taken into consideration if using your truck beyond the manufacturers normal wear and tear, usage guidelines. I, for one, never got this "ball joint pop" after having my 2012 leveled with Bilsteins for two years.
Old 07-09-2014, 09:23 AM
Jeringate's Avatar
Jeringate Jeringate is offline
Vehicle: 2014 Ram 1500 Sport
Rep:12
Jeringate is on a distinguished road
I have a Bilstein leveled 2014. I was kind of worried about this issue too, but I've never really actually heard of someone have a problem... I've only heard numerous people SAY that other people are having problems.
Everything looks really healthy under the truck after my Bilsteins were put in (set @ 2.1) The ball joints don't look like they are at any ugly angle that would cause any problems, same with the Axles. Maybe there was a plague of bad workmanship off the assembly line which caused the issue who knows.
2014 Ram Sport White || Bak Industries Roll X Tonneau Cover || Bak Industries Bak Box || Line X Spray In Bedliner || Bilsteins set @ 2.1 || Pro Comp 5001 Wheels 17x9 -6 Offset || Mickey Thompson Baja MTZ 315/70/17 || Mufflex 18" || Various Stickers For More Horsepower ||
Old 07-12-2014, 11:34 AM
954rrmike's Avatar
954rrmike 954rrmike is offline
Vehicle: 2014 Ram Sport
Trim Level: Sport Crew Cab
954rrmike is on a distinguished road
My 14 with bilstein at 2.1 is fine after 3 months and many miles. Looks so much better as well.
2014 Sport Crew Cab White,8 speed 392LSD,LineX bed liner, Mufflex DOD24M, 18" xd monsters with blizzaks, weather tech floor liners and mudflaps
Old 07-14-2014, 01:17 AM
Deangtp Deangtp is offline
Vehicle: 2014 dodge ram
Trim Level: Black express
Deangtp is on a distinguished road
I just ordered the 5100's. Hopefully no issues
Old 07-18-2014, 03:10 PM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
Like others have said, I haven't heard many instances of Bilsteins ruining the ball joints other than ones that were screw up's on the mechanics part. Most popped ball joints always come from spacer kits. I wouldn't worry much about that with the Bilsteins. Just make sure your mechanic is pretty solid and knows their stuff.
The only problem that ever pops up from the adjustables is shops putting the spring seat upside down.
Hellwig rear sway bar / Green filter / Borla XR-1 / Line-X / Bak Roll-X / AMI shorty antenna / Raptor 4" nerf bar / Mopar tow hooks / Moroso Catch Can / Bilsteins @ 2.1 / Fox 2.0 rear / TGC .75 rear spacer / Air Lift 1000 / Bak Box 2 /
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
