I need help... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 07-10-2014, 12:22 AM
skaling's Avatar
skaling skaling is offline
Vehicle: 2014 1500 Crewcab
Rep:18
skaling is on a distinguished road
Default I need help...
So, looking at trailers, trying to figure things out.
I have a fully loaded ram 1500 CC 4x4 3.21. My sticker in door jam says GVWR is 6900lbs. I took it to the scales. Front axle :1540 kg rear axle: 1180. Total : 2720 kg or 5998lbs. So that only leaves me 900lbs for my hitch weight and passengers.....
Does this seem right? How can my truck be rated to tow @ 7500lbs (10-15% tongue weight @ 600lbs) with so little wiggle room within the GVRW??
Thanks in advance
2014 Ram Sport 4x4 CC short box. 5.7 Hemi, 3.21. Firestone 1000 lbs airbags.
Old 07-11-2014, 01:27 PM
bobbo7915 bobbo7915 is offline
Vehicle: 2014 Ram 1500 QC Express
bobbo7915 is on a distinguished road
your truck weights do seem to be heavier then others i have seen posted....one other 2014 express CC weight in at 5640lbs with driver and a full tank of gas (32gallon tank)
what does your payload sticker say for a weight limit?
Old 07-11-2014, 08:57 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:311
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
Probably for the same reason my Longhorn is rated to tow 9750 lbs, yet my door sticker limits my cargo and passenger weight to 825 lbs. At the local dump, my actual weight came in at 6200 lbs with 32 gallons of gas, me and my Bakflip F1 cover. Be thankful that you at least got the 6900 GVWR, mines 6800. I'm limited to about 6% tongue weight at my maximum towing capacity.
Old 07-11-2014, 11:37 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
Sounds right, the more options, the less capacity.
Old 07-12-2014, 10:40 PM
skaling's Avatar
Rep:18
@1300lbs
Old 07-13-2014, 10:49 PM
Philpaint Philpaint is offline
Vehicle: 2014 RAM 1500 4X4
Rep:16
Philpaint is on a distinguished road
I too have the 6800 GVWR
But it should be the same truck
