Old 07-11-2014, 09:44 AM
birm birm is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Sport Crew Cab 4x4
birm is on a distinguished road
Default Switch Gears from 3.21 to 3.91?
Well I was one of the (un)fortunate few who ordered my truck with 3.55's and got 3.21s due to a shortage, I got an extended warranty and took delivery of my truck because my other vehicle was not cutting it for the growing family.
A year later, I am regretting that decision (gear wise). I love my truck, but it is sluggish, and with the 35's going on next week, will only get worse. I have been scouring the internet looking to see what was needed to go from 3.21 to atleast a 3.91, I was wondering if anyone has done this on a 13 yet? Did you have to change out the front too or just the rear? Does it auto-calibrate or does the speedo need to be adjusted?
Any help is appreciated!
Chris
Old 07-11-2014, 11:58 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I have not done it on a 13 yet, however, you will have to do it on the front as well.
Old 07-11-2014, 08:03 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:545
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Also, on the '13s it is pretty expensive to swap gears. You can't just pop the old ones out and the new ones in, because the carrier or ring gear is welded to something or something like that. I'm not sure about the specifics though since I'm happy with my 3.21s and haven't looked into a swap. Hopefully someone will chime in with more details.
I'm assuming you have the 6 speed? With the 4.71:1 1st gear in my truck (8 speed) I can spin the tires on dry pavement, even with my 3.21 LSD diff.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
Old 07-12-2014, 09:04 PM
I have the 8spd
Old 07-12-2014, 09:18 PM
Rygi Rygi is offline
Vehicle: 2013 Ram
Rygi is on a distinguished road
Can't answer your questions but with the 35s if you only have the 6 speed you should go with 4.10s or it will still be just as sluggish.
Old 07-13-2014, 08:33 AM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
I have 3.55 in mine with the 6spd and I really wish I had 4.10... Dammit why does it have to be so difficult to change... my 35s make my truck pretty sluggish from down low
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 07-14-2014, 07:49 PM
kevster's Avatar
kevster kevster is offline
Vehicle: 2013 RAM 1500 4x4 HEMI CREW
Trim Level: LARAMIE
Color: Mineral grey metallic
kevster is on a distinguished road
I agree 4:10 with 6 speed, a 8 speed however not sure, would say should be safe with 4:10.
2013 RAM 1500 CREW 4X4 LARAMIE.
Old 07-17-2014, 01:18 AM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
With these differentials, it's not just swapping ring gears and pinions. The entire axle assembly has to be replaced. And also remember, the front axle also has to be replaced as well.
Old 07-17-2014, 02:15 AM
Rep:2657
ring gear is welded to the carrier in the ZF rear ends. i believe
older AAM rear ends had the ring gear bolted onto the carrier, 2002 ? - 2010 Ram
2011 they started with the ZF rear ends
Last edited by GTyankee; 07-17-2014 at 03:10 AM. Reason: i corrected a year model mistake
Old 07-17-2014, 02:37 AM
2010 ram 2010 ram is offline
Vehicle: 2013 Ram CrewCab 1500 4x4 8spd
Trim Level: SLT Longstar
2010 ram is on a distinguished road
I too feel the same way i have 8spd 4x4 with 3.21s . I have not done swap yet but thunder is right on 12 and up the front carrrier is welded to the rear gear so you will need to buy and whole new housing from the factory loaded with the 9.92s. or buy a 2010 front end which arent welded and put where gear you want in to match rear but you need a different front drive shaft yoke. as far as rear goes you can buy just the rear gear but it has to be mopar because of the bolt patter. no aftermaket companys make on yet. at least that i have seen. Hope that helps.
