Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 07-12-2014, 10:05 AM
BigE71 BigE71 is offline
Vehicle: 2014 Dodge Ram 2500
BigE71 is on a distinguished road
Default 5th wheel hitch install
We just had a 5th wheel hitch installed on our new 2014 ram. It appears it was installed by drilling holes and securing it to the frame. Will this void the frame warranty? Looking for answers and if this could void the warranty why would a reputable installer install it this way? Thanks.
Old 07-12-2014, 11:40 AM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
As long as it was installed correctly and with proper hardware it should not void or affect the warranty. The hitch should be secured into the frame and your truck is designed for heavy duty work including towing and especially 5th wheel, so a 5th wheel hitch is a required accessory.
Old 07-12-2014, 01:16 PM
RayK RayK is offline
Vehicle: 2014 Ram 2500 Laramie
Rep:72
RayK will become famous soon enough
The 2014 frame was upgraded. As long as the installer used a 5th wheel mount compatible with the 2014, you should be good. Your dealer can inspect and verify the warranty is not being voided. Below is one item from the RAM literature. Congrats on the new truck. I'm loving mine so far.
'50 KSI STEEL FRAME
Strong trucks require a solid foundation. Which is why we’ve equipped the 2014 Ram 2500 with a high-strength 50 ksi steel frame, up from last year’s 35 ksi steel frame. With eight cross members, including a new rear axle cross member for gooseneck or fifth wheel hitch, the new frame provides for thinner-walled, mass-efficient sections without compromising strength'
