Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 07-14-2014, 12:43 AM
blacksmoke06's Avatar
blacksmoke06 blacksmoke06 is offline
Vehicle: 2014 Ram 1500
Color: Blue Streak Pearcoat
blacksmoke06 is on a distinguished road
Default Help! I want this look!
Ok, I came across this truck on the web and want the same look. I have found out these things about it.
The wheels are 20x12 with -44 offset
Tires are Nitto 420s 305/50/20.
What would I expect to trim? Would you stick to only street tires or would A/T tires tear up the paint to bad? Would the ride be harsh with the smaller tire?
I am not lifting it because it has air suspension as does the one in the pictures.
Any suggestions or help in my decisions would be appreciated!
Old 07-14-2014, 12:54 AM
Here is another pic of what I'm after.
Old 07-14-2014, 02:04 AM
freshane freshane is offline
Vehicle: 2014 Ram
freshane is on a distinguished road
Hmm I'm no expert but with that wide of a wheel and offset u will likely need wheel spacers to get give you clearance from rubbing the control arm. That guy probably can't even turn his wheels all the way or must of had to do some major trimming of the plastic in the fender. A 4" lift would give you the clearance but seems like you want that lower look. Maybe a 2" level but those rims are really deep. I like the look as well but that's a crazy offset. Might want to go with -24 max. Good luck
2014 RAM 1500 Sport CC 4x4 6' box 5.7L HEMI
Black Mopar steps,4" Mopar Lift,35" Nitto Trail Grapplers 20" Fuel Hostage II,BushWacker Flares,AVS Visors/Deflector,DeeZee Tailgate (Coming Soon) LED Hood Vent Mod,FX-R HID LED Halo/Strip Retro,LED Fogs,Exhaust,S&B CIA,GatorBack Mudflaps.
Old 07-14-2014, 08:55 AM
jrtubb's Avatar
jrtubb jrtubb is offline
Vehicle: 2014 Ram 1500 Crew Cab 6'4"
jrtubb is on a distinguished road
I have no first hand experience with Ram truck, but based on fixing my wifes Jeep up you need to spend some time researching rims. I agree that offset sound like a lot, if you can get the stock info you can put it in this website with the different rims and tire combos you are looking at.
http://www.rimsntires.com/specspro.jsp
Also those tires are going to tear up the paint with rocks, dirt and sand. You need to add some fender flares, or at least look at the 3M Rocker Panel paint protection for chips. 20 x 9 Sport rims throw a ton of crap and mud on the truck sides I had to add husky mud flaps to help, but they are still a bit wider still.
JR
2014 Ram 1500 Black Big Horn Sport! Crew Cab 6'4", Custom Katzkin Red and Black Interior, My Changes!
Old 07-14-2014, 09:00 AM
dizzle dizzle is offline
Vehicle: 2013 Ram 1500 Ext. Cab 4x4
Color: True Blue Pearl
dizzle is on a distinguished road
w/o fender flares and tires that wide, you would most defiantly chew up your paint (no mud flaps or flares) where i come from that would also get you pulled over constantly as you would be shooting water/dust/sand at the vehicle behind you from not having flares,
my suggestion to you would be to do a little more research on what your after as "i want mine like his" doesn't help you unless you know more information about "his truck"
this information would be provided to you by any knowledgeable tire sales department, hit up the forums, when your adding bigger rims/tires without adding any sort of lift you cant expect things to preform like stock.
normally bigger tires are accompanied with a lift of some sort, ive seen new Rams that rub w/o even changing tires. can guarantee you that guy cannot crank his wheels completely left or right w/o rubbing as noted above.
Old 07-28-2014, 09:06 PM
Well I finally found the guy and talked to him. I pulled the trigger last Thursday 20x12 on 305/50/20 Toyo AT II. Only had to trim the mud flaps. I love the look!
Old 07-28-2014, 09:11 PM
Here is another pic.
Old 07-28-2014, 09:21 PM
Geniusgene's Avatar
Geniusgene Geniusgene is offline
Vehicle: 2010 Ram 1500 QC
Color: Inferno red pearl
Geniusgene is on a distinguished road
looks cool. do they rub?
BT catch can, Borla pro xs, Afe drop in filter.
Old 07-28-2014, 09:29 PM
After I trimmed the mud flaps I have not had any rubbing. Very surprised they fit! 99% of everyone I spoke with said it was not possible to fit that combo under that truck.
Old 07-28-2014, 09:38 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Trim Level: Express RC
Color: Black Express Package
Rep:67
I am pretty amazed they fit with just trimming the mudflap myself. I didn't think you could get rim width with that offset without a lift.
