Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 07-18-2014, 12:43 PM
RamRod37's Avatar
RamRod37 RamRod37 is offline
Vehicle: 2005 Dodge ram 1500 QC 2WD
RamRod37 is on a distinguished road
Default Oh Crap Busted heater core Not Good
Whats A Good Stop Leak Now Im Not not In Mood To Spend 8-12 hrs taking The Whole Dash Out right now Is There Some Good Stop Leak I would Just Bypass It But Winter Will Be Here Before You Know It
Old 07-18-2014, 12:53 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Rep:194
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Using a stop leak solution in the rad to help seal the core will cause you more grief in other areas. Best bet is to just loop one of the hose back into the system to avoid any more leakage.
Old 07-18-2014, 02:12 PM
HemiLonestar's Avatar
Rep:280
This happened to me on the road, I took a small piece of pipe and tied the heater hoses together to bypass the core completely. He's right about the stop leak, it will cause grief later (like when your rad plugs up, or water pump goes; ask me how I know...).
"Big Red"
2006 Charger R/T
Old 07-18-2014, 02:29 PM
RamRod37's Avatar
Yeah But Id Rather Change The rad And The Water Pump Than Have to Pull My Whole Dash, Steering Column out my opinion Im Going to try some Stop Leak I Don't want to bypass cause then winter no heat so Ill see what happens
Rad Rodded out here is just 50 bucks so Ill Take chance on it
Old 07-19-2014, 07:12 AM
RamRod37's Avatar
Ok Iv Got Another Question Is The Blend Door In Same Area As Heater Core The Reason I Ask is my vents worked fine till the heater core busted now iv got no temp controlled air on driver side Could a Broken Blend door be able to fall into heater core Im Thinking It may Have Busted The Core But I Don't Know Cause Iv Never Looked at A Internal Breakdown Of Heater Box On My Truck I Just Find It Odd That That happened same time
Old 07-19-2014, 08:38 AM
namretsud's Avatar
Rep:194
To fix both there is only one solution and it is the one you are trying to avoid. In the long run you are going to cause yourself more grief and $$$$$$$$$$$.
Old 07-19-2014, 12:00 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
The blend door and the heater core are pretty close to each other but I doubt they would come in contact. There are several threads where owners were experiencing a large temperature difference from one side of the truck to the other and most of those seemed to be resolved by flushing and properly filling or complete replacement of the heater core. There has been some speculation that the blend door can cause this issue but in the threads I have read multiple owners with this problem have found their blend door to be perfectly fine and later resolved the issue with the heater core. In short, I think your heater core is the source of all your issues. When the time comes to replace it I would consider replacing all your HVAC doors as a precautionary measure at the same time and you should never have to worry about the internal portion of your HVAC system again.
Old 07-20-2014, 07:35 PM
Rep:280
Do what I did. Bite the bullet, pull the dash, replace the core, the blend door and evap coil while you're in there. My dash was cracked so I replaced that too.
"Big Red"
2006 Charger R/T
Old 07-20-2014, 07:40 PM
Rep:2705
check out the HeaterTreater Dodge website
it will answer most of your questions
as for the heater core ...
https://www.youtube.com/results?sear...2005+dodge+ram
Old 07-21-2014, 01:34 AM
RamRod37's Avatar
Thanks I got Covered now Leak fixed
