Single Disc Remote CD Player - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 07-20-2014, 08:36 PM
UpToNoGood's Avatar
UpToNoGood UpToNoGood is offline
Vehicle: 2014 Ram EcoDiesel
Trim Level: Laramie Longhorn
Rep:61
UpToNoGood will become famous soon enough
Default Single Disc Remote CD Player
Can anyone with the CD player confirm if it is permanent or can it be removed from the center console.
2014 1500 Laramie Longhorn CC 4x4 8spd, 3.92 EcoDiesel - Hammerhead rear bumper sprayed with Linex - Iron Cross steps sprayed with Linex - Trucks cover tool box/Tonneau Cover combo - Geno's cabin filter - 275-65-20 Nitto Terra Grappler - Air Lift 1000
Old 07-20-2014, 10:29 PM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:103
Rambunkshuss will become famous soon enoughRambunkshuss will become famous soon enough
I have one in mine (14 sport w/8.4 radio w/optional CD player), i havent found how its mounted in there yet, but i`m sure you could take it out if you wanted to. You`d likely have to pull the complete lower console out of the truck. I`m thinkin the mounting bolts come up thru the bottom of the lower console and fasten the CD player to the console.
Life`s tough, its even tougher if you`re stupid
Old 07-20-2014, 11:07 PM
UpToNoGood's Avatar
Rep:61
The reason I ask is I currently have a 2013 Ram 1500 Laramie with just about everything, but the CD player. I bought an after market safe that mounts in the lower part of the console. It won't fit if the CD player is present.
So I am now searching for a 2014 1500 EcoDiesel. During my search I come across many trucks that have the CD palyer and I was wondering if it can be removed so my safe can be added. I have no need for the CD palyer.
Old 07-21-2014, 12:09 AM
Rep:103
I might be wrong here, but i think ther are 2 different lower compartments, one that excepts the CD player (which is likely narrower in width so it house`s the CD player), and just the plain lower compartment without the CD player option, which is more wider due to it not needing the CD player. It looks like mine sits in its own enclosed compartment within the lower console compartment. Hopefully someone with the right info will chime in here for ya, i`m just shootin in the dark here.
Old 07-21-2014, 09:20 AM
furian furian is offline
Vehicle: 2014 Dodge Ram 1500
furian is on a distinguished road
I just checked mine and its a molded piece... if you removed the CD player, you would staill have the raised plastic there. You would need to replace that with the part they put in if the CD was never installed, or cut it away to fit a safe.
Old 07-21-2014, 03:47 PM
UpToNoGood's Avatar
Rep:61
Is that CD player in the upper or lower part of the console? It is hard to tell from the photo. My safe goes in the lower part of the console.
Old 07-21-2014, 05:08 PM
bumski's Avatar
bumski bumski is offline
Vehicle: 2014 Ram 1500
Color: Blue Streak Pearl
bumski is on a distinguished road
Player is in the lower part of the console. They do make a version of the safe that fits with the CD player
Old 07-21-2014, 08:46 PM
Correct, it is the very lower part of the console
Old 07-22-2014, 12:40 AM
Rep:103
Enlighten us on where to find one. Do you have any links you could post in here...?
Old 07-22-2014, 12:58 AM
UpToNoGood's Avatar
Rep:61
Here http://www.consolevault.com/Dodge-Ra...2014_p_93.html
