Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
tonneaucovered.com
Old 07-24-2014, 09:33 PM
BigT BigT is offline
Vehicle: 2014 Ram 1500
Trim Level: Limited
BigT is on a distinguished road
Default Question on hitch balls
I have a 1500 and I'm looking to buy a popup camper. I've never towed before but I have the receiver hitch and everything. What is the standard ball size and type to get to tow a popup camper? I'm looking to buy a used one so I wanted to be ready in case I find one.
Old 07-24-2014, 09:48 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Most popups I've seen use a 2" ball. You're probably better to wait until you find a trailer you like so you can get the proper hitch drop. You want the trailer to tow level front-to-back.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 07-24-2014, 09:57 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
CrazyCanuck is spot on. It is typically the larger trailers that use a larger ball than 2 inches, so you should be good to go with a 2", they are pretty standard. And definitely wait on the trailer before purchasing a bar. If you do decide on a trailer, if it is not parked level, get it level from front to back, then you can measure the height of the hitch. In the mean time you can measure the height of your receiver on a level surface. Once you know these two numbers, you can figure the drop you will need.
Old 07-24-2014, 10:21 PM
Trim Level: Limited
Thanks!
