Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Media Zone > Dodge Ram Videos
Dodge Ram Videos Post links to cool Dodge Ram Videos here!
Old 07-27-2014, 11:35 PM
Ram18 Ram18 is offline
Vehicle: 2014 Ram Sport CC 4X4
Rep:14
Ram18 is on a distinguished road
Old 07-27-2014, 11:40 PM
PTCTreeGuy PTCTreeGuy is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman
Color: True Blue with Black
Rep:39
PTCTreeGuy is on a distinguished road
Originally Posted by tf28 View Post
Yeah thought maybe tire grip but what about when they were in L4? Was done for fun regardless not trying to prove/disprove anything.
Some how L4 changed the trucks to having tracks, spikes, maybe nailed to the ground?? It still has to use the TIRES to grip the road.
Probably the worst thread on here and definitely not worthy of the bandwidth needed to host it.
Old 07-28-2014, 12:14 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Cool test in L4 as well but still, tire grip is essential. Michelins are much grippier compound than our Crapyears. All of us Ram owners know the OE Goodyears are junk when it comes to grip. The Tundra clearly is a worthy adversary but properly equipped shoes are a must when trying to grip cement, asphalt. I do know your Tundra most likely has a 4.30 rear gear. What does your Ram have? 3.21's? If your Ram has 3.92's coupled with the 8HP70 and mount the same brand rubber on both trucks with same air pressures,.........it would then be closely matched. Tug of war only demonstrates who holds their brakes long enough to get the opposing to loose grip by burning rubber, then the other truck simply rolls away by properly modulating the gas and brake pedal so as to stay in the torque powerband. Tricks and tips brother and a good sticky set of Nitto Drag radials aired down to 20 psi.
Old 07-28-2014, 02:27 AM
VectorZ's Avatar
VectorZ VectorZ is offline
Vehicle: 2014 Ram 1500 4x4
Trim Level: Laramie long bed CC
Color: White/Silver
Rep:47
VectorZ is on a distinguished road
I found it entertaining, what somebody else chooses to do with their trucks is their business. It would be fun to see the two trucks with the same tires and gear ratios do the test.
Old 07-28-2014, 01:26 PM
tf28 tf28 is offline
Vehicle: 2014 dodge ram 1500
Trim Level: sport 1500
tf28 is on a distinguished road
To be honest have no idea what ratio the dodge is running but I completely agree with that point, I plan on doing a few more comparisons. Absolutely right about the tire brands but to be honest think the ratio prob has more to do with it from the video, but who knows exactly. Form the specs the tundra does seem to reach peak torque earlier (albeit slightly).
Old 07-28-2014, 01:30 PM
can definitely change the tires, gear ratios though have no idea..
Mate calm down, I was referring to L4 test when tire slippage wasn't so much an issue the result was still the same. No need to be so emotional
Old 07-28-2014, 02:01 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:616
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
Also agree that the test in 4 low makes no difference since tire traction is the limiting factor. Try it with similar rubbers on and then see the result, and by similar I mean same model of tire, same width, etc... Also do both have LSD?
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 11-28-2014, 05:29 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
I just think those exoctic cars in your other videos are cool as hell. Not gonna beat the dead horse about tire traction, gearing and all the other bs like the others. The new tundras are not my cup of tea and do find them fugly, but they are a nice truck in a way and much better then what they used to be. Also can't deny that they have stepped up their full size truck game too, which benefits everyone because the results is all companies continuing with improvements to stay new and not fall behind. Looks like you got yourself a nice selections of trucks to choose for the morning
IG:@briley59
