Old 07-30-2014, 11:45 AM
tommyj tommyj is offline
Vehicle: 2014 dodge ram 2500
Trim Level: Longhorn Laramie
tommyj is on a distinguished road
Default Trailer Breaking Messages
Just bought a 5th Wheel (~16K lbs) and when I pulled it home I kept getting error messages on EVIC. One was "Check Trailer Wiring" and the other was "Trailer Brakes Not Connected". I have unplugged, replugged, turned off, restarted? We had fifth wheel hitch installed after arket and had plug moved to bed of truck as well.
Old 07-30-2014, 01:10 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
Try squirting some electrical contact cleaner in the connections and maybe massaging with a pipe cleaner or something similar.
Old 07-30-2014, 07:24 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
I had a similar message. It turned out to be a frayed wire in one of the trailer brakes.
Old 08-01-2014, 02:04 PM
Foog Foog is offline
Vehicle: 2012 1500 Crew
Trim Level: Outdoorsman
Color: Grey
Foog is on a distinguished road
Just had the same message pop up in my truck - but only when headlights are on.
Everything is dandy with all lights on truck and trailer until I turn on my headlights...then lights on truck are still fine but no trailer lights and brake controller message.
Ideas?
Old 08-02-2014, 11:38 AM
clatla's Avatar
Color: Snow White
Rep:31
Would be willing to be there is a short in the wiring. Check inside the plug from truck to trailer and junction box on trailer. Tracking them down sucks. Good Luck.
Old 08-03-2014, 07:37 AM
ramit355's Avatar
ramit355 ramit355 is offline
Vehicle: 2014 1500 4x4 CC Laramie 392
Trim Level: Laramie Crew Cab
Rep:28
ramit355 is on a distinguished road
Every camper I have owned when I have Electrical issues has always been in the following three places. !.The Plug in Connector worn out or Frayed or rusted in side. (Harley Davidson makes a Gel for Electrical connections of the ECM under the seat that takes much water at times and cures all connection from rust Etc Etc.) If its not the Connector Plug or Female Connector.... 2. Follow your Trailer wire back about 5 to 10 feet where the Plastic Connectors that connect the trailer wiring to the Connector Plug Wiring and you will find water damage INSIDE the connectors looking Perfect from the Outside Inspection! If none of the above has Issues 3. Go to the Trailer rear tail lights and look inside from where water got in the "sealed" Cover and trashed the Plastic connectors inside the housing causing it to short out. Hope that saves you much time and Expense.
Old 08-03-2014, 01:45 PM
Color: Grey
Thanks for the advice. Hope to have some time tomorrow to start the troubleshooting.
Old 08-03-2014, 03:17 PM
ramit355's Avatar
Rep:28
Y.W. Good luck to you Sir.
Old 08-06-2014, 03:39 PM
Color: Grey
Smile
Fixed...indeed a ground wire had pulled out of its connector in the wiring box at the front of the trailer. Would have been a 5 minute fix except I was out of the right size of crimp connector and had to go buy some.
Thanks for the tips!
Old 08-06-2014, 06:32 PM
ramit355's Avatar
Rep:28
ha ha...we never have what we need on hand no matter what!! Your welcome glad to help out.
