Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
tonneaucovered.com
Old 08-01-2014, 11:43 PM
hokietiger's Avatar
hokietiger hokietiger is offline
Vehicle: 1989 Dodge PowerRam w100..4x4
Trim Level: standard
Color: Crimson
hokietiger is on a distinguished road
Question 1989 Power Ram W100...318 v8...MAP SENSOR question
Hi gang,
Will a failing MAP SENSOR in a 1989 W100 Power Ram (318 c.i./5.2 L with EFI throttle body) start causing idle issues?? (came up on engine codes when checked, along with IDLE CONTROL SOLENOID issues....I've done the following to my truck:
1. New plugs, air filter, pcv valve, wires, dist.cap/rotor, and new ignition pickup in distributor.
2. New fuel filter.
3. Cleaned and lubed the IDLE CONTROL SOLENOID
4. New vacuum hoses on MAP sensor.
5. Rebuilt throttle body with new gaskets and injector O-rings (also cleaned entire throttle body, all ports, and vacuum inlets with carb cleaner).
It seems the IDLE CONTROL SOLENOID works OK with no internal damage (took apart, inspected, and re-lubed).. However, it will move somewhat from low idle back to normal idle during idle in PARK. And, when I cleared the codes and restarted the motor, the new codes only indicated an IDLE AIR SOLENOID problem and not the MAP sensor....Strange!!
I'm at my wits end and now suspect the MAP sensor might be going bad......The truck starts up nicely and idles wonderfully at cold startup. Then, after warmup, it begins to idle sporadically from normal to low idle and will sometimes stall.
Help!!!
Mike
Old 08-04-2014, 12:34 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Have you done code check? I've watched you go through a lot all over the place. Now map and tps should set warning light but not every time. To do the code check turn ignition on and off 3 time's after the 3rd time leave it in run DON'T START. Then the check engine light will flash a 2 digit code. With the end code being 55. This might help the run around you are having. Now things I know can cause your condition. A straight up vacuum leak. Bad map venting vacuum prematurely. And tps not sending strong enough signals to computer at idle.
Old 08-04-2014, 01:05 PM
ramfam's Avatar
Trim Level: Base
Rep:21
http://dodgeram.info/Engine-Gas/OBDI/Fault-24.htm I hope it works and helps also http://www.allpar.com/fix/idling-repair.html
