Power To Radar Detector - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Bayou Goat Mounts - Ram Truck GPS/Cell Phone/Radar Detector Mounts
Bayou Goat Mounts - Ram Truck GPS/Cell Phone/Radar Detector Mounts Bayou Goat Mounts has designed the only mount made specifically for the  2009-2017 Ram Trucks. Our mount gives you the ability to mount your GPS, Cell Phone, or Radar Detector at the best possible spot on your Ram Truck Dash. With easy installation using factory screws already on your dash, this mount gives you a low profile look with easy access. Check out our sleek looking mounts at: bayougoatmounts.com
Old 08-03-2014, 12:18 PM
Cammin Hemi's Avatar
Cammin Hemi Cammin Hemi is offline
Vehicle: 2014 Ram R/T
Trim Level: RT
Color: Blue Streak Pearl
Rep:18
Cammin Hemi is on a distinguished road
Default Power To Radar Detector
What is the best way to hide the power wire to my radar detector and would I need a special cord? I have a Belltronics 955 plugged in to the center console cigarette lighter right now and suction cupped to the windshield. This new mount along with hiding the power wire would look very clean! Thanks!
2004 Dodge Hemi standard cab short bed "gone but not forgotten".
Old 08-03-2014, 01:42 PM
rcmpvet's Avatar
rcmpvet rcmpvet is offline
Vehicle: 2014 Ram
Color: Black Gold Pearlcoat
Rep:51
rcmpvet will become famous soon enough
When you remove the two screws holding the top of the dash console you will see there is a little hole there that your wires should fit into. Once you remove the console (there may be a 3rd screw in the cubby above the USB port on the right. (screws are T20 torx).
The console pulls right off, just work your way around it and you may then have to unplug the various components to be able to work in the area.
There is a lot of room for loose wires back of the console and you will be able to unplug the power from the back of the cigar lighter. You will then be able to tap into the power and negative wires for that lighter and put back in place.
Here is a thread done by SShadow1974 - http://www.ramforumz.com/showthread.php?t=170812 This should help.
There Is No Such Thing As A Stupid Question: HOWEVER: Search Function is Your Friend
Old 08-03-2014, 02:16 PM
Trim Level: RT
Rep:18
Thanks a lot! My cigar lighter is in the front storage bin of the floor console of my RT. Is it a pia to get to the cigar/charger socket wiring inside the floor console?
Old 08-03-2014, 05:26 PM
rcmpvet's Avatar
Vehicle: 2014 Ram
Rep:51
That I couldn't tell you as I do not have that trim. I have the full bench seat with hidden console, no electronics in that seat portion.
