Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-03-2014, 11:09 PM
Cammin Hemi's Avatar
Cammin Hemi Cammin Hemi is offline
Vehicle: 2014 Ram R/T
Trim Level: RT
Color: Blue Streak Pearl
Rep:18
Cammin Hemi is on a distinguished road
Question 8.4A Heater Question
Is this correct? To operate the heater bring up the climate control screen, set the temp desired with the up & down arrows on the touch screen, select the vents on the touch screen, and finally set the fan speed with the touch screen or the fan control knob. There is no selection marked "heat". I do not have the "auto" or dual zone HVAC. Is this correct or am I missing something? I'm a technically challenged old fart! All my other vehicles just had knobs! Thanks!!!!!!!!!!!!!!!!!!!
2004 Dodge Hemi standard cab short bed "gone but not forgotten".
Old 08-04-2014, 08:59 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
Easiest way is to just use the buttons and knobs under the screen. But yes you set the temp you want and adjust the fan speed. I have the auto dual zone so I just leave it on 70 if the windows are up regardless of winter or summer and it adjusts accordingly
Old 08-04-2014, 10:46 AM
rcmpvet's Avatar
rcmpvet rcmpvet is offline
Vehicle: 2014 Ram
Color: Black Gold Pearlcoat
Rep:38
rcmpvet is on a distinguished road
You do not have to operate "Heat" via the touch screen. All you have to do is ensure that the A/C is off, there is a button for that. Then you can adjust the temperature with the two buttons on the console. If you want defrost that is all you have to touch, then the temperature buttons and the fan speed button. To select the actual airflow you do have to go into the climate controls via the touch screen.
There Is No Such Thing As A Stupid Question: HOWEVER: Search Function is Your Friend
