Old 08-08-2014, 08:19 PM
bullyt bullyt is offline
Vehicle: 2009 Dodge Ram
bullyt is on a distinguished road
Default Transmission clunk 2nd to 1st downshift
2009 Ram Hemi with 200,000 km (120,000 miles). I get a periodic "clunk" on the 2nd to 1st downshift. It's not a bang and nothing abrupt but about once a week I'll get a bit of a clunk on the downshift. Last week I was slowing behind truck going up a hill and I got a slight clunk...I believe it was 4th to 3rd. The tranny always shifts perfectly on acceleration...nice and smooth. I changed the transmission fluid and filter at 70,000 km (42,000 miles) and then I had a full flush done at 185,000 km. After the flush I went several weeks without a single clunk but now it's about once a week again. Hard to recall exactly, but I first noticed the occasional clunk around 160,000 km (100,000 miles).
Any thoughts? Not sure if it's the inevitable sign that the tranny is starting to go or if it's something repairable (aside from rebuild)? Appreciate any comments.
Old 08-09-2014, 12:20 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Mine did the same thing a few of times in 4th and twice a code appeared so I re flashed it with my tuner. Of course I was worried about the same thing but it went away and the thump did as well. The code was P0734 diagnosed as "incorrect gear ratio". I think it has something to do with the input and output speed sensors not matching up with the gear ratios. I also remember reading somewhere when I researched the code that it could be 4th gear clutch plate maybe? Other than my truck taking off quicker than normal without trying to hard because of my 3.92 gears/30.5 inch tires I drive my truck pretty easy. I usually stay around 2 to 3k rpms during my daily driving leveling off at 2k being 70 mph so I don't think it has anything to do with bad driving habits. Not saying mine won't fail but at least it's not the coil packs. Not to mention my lifetime drivetrain warranty should cover it. Just try to keep a log on the times and keep an eye out for codes. If one does appear you can google it and it will most likely guide you right here to the correct thread in the Z for a fix or reason for it. Good luck
