Place your Ad Here!
Old 08-13-2014, 08:14 AM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:207
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
Default towing
I have an 09 sport crew. I have been towing with it since day one. For some reason the brakes don't work with the trailer anymore. I had the trailer looked at and the brakes work on the the trail but when its attached to the truck nothing happens. Is there a fuse on the truck or do you think that my trail brake controller is broken. When I push the brake button on the controller it tells me there is nothing connected to it. Any help would be great.
Thanks
Old 08-13-2014, 10:32 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
It is possible there is a problem with your BC, but it is more likely there is a bad connection. Looking for a bad fuse is worth a start. Then I would spray some electric contact cleaner into both connections (trailer & truck sides) and maybe some mechanical means to scrape the contacts. If that does not solve the problem a multimeter will come in handy to look for a broken or compromised wire in the trailer or the truck. If all wires test functional, likely the BC may have gone bad, but also make sure you still have a sound connection at the BC.
Old 06-21-2017, 01:42 PM
ericjohnson114 ericjohnson114 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Bright Metallic Sliver
ericjohnson114 is on a distinguished road
I have a 09 1500 5.7 hemi I tow a travel trailer between 6,000 and 6,500 lbs around mid-Atlantic with no problems. Thinking about going out west, think it will handle going over the Rockies?
Old 06-21-2017, 04:06 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
It will.
http://www.ramforumz.com/showthread.php?t=116290
http://www.ramforumz.com/showthread.php?t=178993
