View Poll Results: What Brand of Motor Oil Do You Use?
Amsoil 99 10.45%
Castrol 82 8.66%
Dealer 60 6.34%
Havoline 6 0.63%
Mobil 324 34.21%
Pennzoil 115 12.14%
Quarker State 34 3.59%
Royal Purple 90 9.50%
Vavoline 83 8.76%
Not Listed 54 5.70%
Voters: 947. You may not vote on this poll
Old 11-16-2012, 09:58 AM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
royal purple here
Old 12-06-2012, 01:13 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Mobil 1 5w-20 here.
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 12-06-2012, 04:34 PM
bighemi04's Avatar
Vehicle: 2014 Charger RT AWD
Rep:623
For everyone that uses something other than Amsoil, I know it is personal preference, however I challange you to study up on what you use. Amsoil destroys the competition in nearly all ASTM testing. Use these test results and stack them up against your favorite oil
TYPICAL TECHNICAL PROPERTIES
Signature Series 5W-20 Synthetic Motor Oil (ALM)
Kinematic Viscosity @ 100C, cSt (ASTM D-445)
8.8
Kinematic Viscosity @ 40C, cSt (ASTM D-445)
50.5
Viscosity Index (ASTM D-2270)
153
CCS Viscosity, cP @ (C) (ASTM D-5293
4054 (-30)
Flash Point C (F) (ASTM D-92)
228 (442)
Fire Point C (F) (ASTM D-92)
246 (475)
Pour Point C (F) (ASTM D-97)
-51 (-60)
NOACK Volatility, % weight loss (g/100g) (ASTM D-5800)
5.70%
High Temperature/High Shear Viscosity
@ 150C, 1.0 X 106 s.-1), cP (ASTM D-5481)
2.8
Four-Ball Wear Test @ 40 kgf, 75C,
1200 rpm, 1 hr, scar diameter, mm (ASTM D-4172)
0.35
Total Base Number (ASTM D-2896)
12.6
Old 12-27-2012, 09:27 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
I use Amsoil! just did the first oil change on my 2012 with 5w20 signature series about 400 miles ago
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 12-27-2012, 09:29 PM
Danzanzio's Avatar
Danzanzio Danzanzio is offline
Vehicle: '05 Dodge Ram
Color: Atlantic Blue
Rep:86
Danzanzio will become famous soon enough
I have always gone the cheap route and used whatever was on special at Advanced Auto Parts which was usually pennzoil and a filter for a little over $20. But I just got a new job at Valvoline so I think I'm going to switch to the Valvoline SynPower Full Synthetic oil since I can get a 50% discount for a full service oil change.
Old 12-27-2012, 10:10 PM
Danzanzio's Avatar
Rep:86
i have run the best Castrol in all my 4 wheel vehicles, But, Kendall in my Harley, thicker viscosity in summer & thinner in our so called winter
the Ram has been done by the dealership so far & they recently changed suppliers, they were using Mobil1, i heard that they changed from that
someone posted that they used Jiffy Lube for their oil changes, you should know that they have had several stores that have been caught re-using old oil bottles & refilling them with a cheaper product. I caught them trying to put Valvoline in my last truck & I had made sure that Castrol was on the print out, they asked me why it mattered so much, I never went back to that store/shop
as far as oil filters are concerned, FRAM is crap, they use cardboard end caps & they blow out, check the filter chart that is posted above. WIX is a preferred filter, built much better & better flow
Hahahaha! I can't believe Jiffy Lube tried using Valvoline oil! I now work for VIOC and they are our supposed competition. I've also heard that Jiffy lube is a bad place, for the customers and the employees.
Old 01-20-2013, 08:56 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
jiffy lube sucks. i used to work there. managers and employees working on cars in the parking lot pocketing the cash on the clock, doing oil changes and pocketing the cash with the stores oil. very crooked place.
i use mobile1
2005 Dodge NSRT-4
Old 01-20-2013, 09:31 PM
bighemi04's Avatar
Rep:623
Yea Goofy Lube is a joke.
Old 01-20-2013, 09:40 PM
slowram slowram is offline
Vehicle: 2005 Dodge Ram
Trim Level: Hemi Sport
slowram is on a distinguished road
Mobile1 all the way here...
Old 01-21-2013, 03:53 AM
SoCal Ram's Avatar
SoCal Ram SoCal Ram is offline
Vehicle: 2012 RAM 1500
Rep:294
SoCal Ram is a jewel in the roughSoCal Ram is a jewel in the roughSoCal Ram is a jewel in the rough
Have always used Valvoline. jhinkle1989 is put'n up a real good argument for AMSoil. Anyone compare the two, or anything to AMSoil?
