Old 10-01-2008, 04:56 AM
Aves's Avatar
Aves Aves is offline
Vehicle: 2011 RC
Trim Level: R/T
Color: Minerial grey
Aves is on a distinguished road
Originally Posted by SlIcKSRT View Post
It's hard to tune the PCM cause it's almost not able to.. Reflashing it and calibrating it might work, but you might have to start from scratch and install a writable PCM and calibrate it your self using a lap top and the software.... Depends on what your looking to do.. That route would be for max horse power.. That shop should find a pcm calibrated for all adjustments after the power adder was installed.. good luck reconfiguring the stock one.. like i said, doing that makes the truck act like it doesn't know what to do.. That belt problem sounds like a mis-installed S/C, bracket, wrong pullies..?? Great lookin trucks though..
Actually SCT finally makes a tuner for them, but you run into 2 problems plus 1 just for s/c applications. First hardly any tuners out there buy the software from SCT for fact that they are charging $2500 for each type of dodge ( ie 1 for viper, 1 for hemi,1 for srt-4 types, and one for jtec obd2). There is a couple tuners out there doing great things with them but none local so you send off logs and then wait for an e-mail back with new tune,but still beats the old sending the pcm out to get reflashed. Secondly SCT butchered the tuning capabilities allowed for dodge compared to other makes. Basically the send out a alpha version and then made somethings worse with updates. Then lastly Dodge pcm hate boost. So what you end up with is using a 2 bar map sensor and cutting your voltage in half to it. By doing this you end up running twice the size injector you actually need. I am running 60lb injectors on mine with 33% being pulled at idle.
As far as the belt thing goes I just can't find the right size belt since I switched to a smaller pulley. I am running a 113" belt and they next size down I could find is around 109 where I need about a 112. Belt slip is a big problem with these set-up once you try over 8lbs. Hopefully I will have this fixed this weekend with a different idler pulley and spacers under they A/C. If that does not work will be going with a Richard Racing ultragrip pulley.
Sorry for typos, misspelling
Troy
2008 Ram 1500 RC Sport
1999 Dakota R/T
Old 10-15-2008, 04:50 PM
Aves's Avatar
Vehicle: 2011 RC
Trim Level: R/T
Well getting ready to go track with dakota went to the dyno see what kinda power it is running. This is with a very safe tune( only 22* timing at top) and still a bit fat(10.5to1) at 5400rpm. Peak power was 365hp and 370 tq.
Sean(aka Hemifever) is suppose to send me another tune to lean it out a bit at top end but probably leaving it safe tune with timing. I am still running on the stock bottom end with 95k miles on it .
Troy
1999 Dakota R/T
Old 04-25-2009, 01:27 AM
07Ram1500's Avatar
07Ram1500 07Ram1500 is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Color: Electric Blue Metallic
Rep:15
07Ram1500 is on a distinguished road
I like the Ram!!!
