Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-05-2008, 07:12 PM
r3d47
Default Makes a weird noise turning left?!
Vehicle: Dodge Ram 1500 5.9 4x4 Laramie Sport
Q: This truck makes a swirling metallic noise close to the axle when steering left but doesnt seem to be rotating as fast as the axle or tire when driving. When inspected by the eye it doesn't have any noticeable damage however can be heard inside the cabin when making a left and increases in noise volume when further pressed into the left direction. The steering wheel has some play in it! When making the left turn there is an apparent portion of slack before it starts to turn in either direction. Weird enough though when traveling in a left direction the noise seems to disappear momentarily whence directed towards right and placed in this free slack while the truck continues in a left direction. Oh and the slack is more apparent when traveling in a straight line making interstate travel more like an exercise from correcting it constantly. I put a new monroe steering stabilizer on it but its done nothing for the thing at all. I had an alignment done and the steering is still off.
Old 10-06-2008, 03:58 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Sorry I don't have an answer for you, just wanted to say hi and welcome! Why don't you head over the the newbie section and introduce yourself so we can greet you all proper like!
Old 10-08-2008, 08:47 PM
MeanGirl's Avatar
MeanGirl MeanGirl is offline
Vehicle: Nitro
Color: the only color-BLACK!
Rep:32
MeanGirl is on a distinguished road
my answer is only turn right then....lol. sorry, hope someone comes along soon and has the answer for you that will help!
Old 06-14-2009, 11:58 PM
jjtroutbum's Avatar
jjtroutbum jjtroutbum is offline
Vehicle: 1996 RAM1500
Trim Level: SPORT
Color: BLACK
Rep:17
jjtroutbum is on a distinguished road
My truck has exact same symptoms going on but its when making a right hand turn. wish someone would have been able to answer your question
Old 06-15-2009, 09:49 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Ball joints perhaps? Causing too much slack in the spindle?
Old 06-16-2009, 11:51 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
The steering should not have any "play" in it. You should have that looked at before something happens like a bad ball joint.
Old 06-17-2009, 12:04 AM
jjtroutbum's Avatar
Trim Level: SPORT
Color: BLACK
Rep:17
Yep I do have bad ball joints bought new ones already would be on today but was raining most of the day and well the garage is "unavailable."
Does have a little play in the wheel hopefully the ball joint replacing all of em will tighten it up.
Read something about the shield behind the rotors also. Will get to that and bearings once I get it up with the front wheels off.
Old 06-17-2009, 12:50 AM
Yes, check that brake shield. Also check to see that your brake pads are fully seated in the caliper and aren't loose!
Old 06-17-2009, 12:53 AM
jjtroutbum's Avatar
Trim Level: SPORT
Color: BLACK
Rep:17
That's just a tad scary sounding. I know I will not for get that now!
Thanks...for the bad dreams...lol
Old 06-17-2009, 12:56 AM
LOL...didn't mean to cause you a nightmare but I've seen this happen. Also, sometimes a brake pad will warp or crack and cause this noise as it's no longer in the correct orientation to the rotor.
