United Radio
Old 10-09-2008, 08:37 PM
lowhand lowhand is offline
Vehicle: 19985.5 Ram 4x4 diesel short b
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
lowhand is on a distinguished road
Default replacing an alternator
Can anyone tell me how to go about this? I have a 98.5 5.9 L diesel 4X4 Is it an easy swapout?
Do I have to release the tension on the serpintine belt and move
the belt and just undo bolts on alt?
Thanks for any input...
Old 10-09-2008, 09:13 PM
DaveDees's Avatar
DaveDees DaveDees is offline
Vehicle: 2010 Jeep Patriot
Trim Level: Latitude
Rep:40
DaveDees is on a distinguished road
Here you go this will give a step by step on replacing your alternator:
http://www.mobiloil.com/USA-English/...ator.aspx?pg=3
I notice this is your first post, please be kind an introduce yourself here.
Newbie Checkin
All articles that coruscate with resplendence are not truly auriferous.
Old 10-10-2008, 04:58 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Hello and welcome!
Good to see you out here!! If you don't mind, tell us about yourself and your truck in the newbie section so we can greet you proper!! Enjoy the board! I hope the link Dave posted for you helps!
Old 10-10-2008, 03:32 PM
03ramhemi's Avatar
03ramhemi 03ramhemi is offline
Vehicle: 2003 Dodge Ram 1500 QC Hemi
Color: 2 tone, black with silver
Rep:14
03ramhemi is on a distinguished road
ya thats all it should be, remove the tension on the belt, unhook it, 2 main bolts that hold the alternator, maybe a few sub bolts depending, n just the power plugs that go into the alternator, then reverse to put it back together, alternators are usually a simple swap unless you a transverse mounted v6 then its a real pain in the ass, but a big engine compartment n v8 your alright, i had to replace the alternator on both of my trucks but they 5.7L one was chevy n i had to do it to my HEMI as well. Good luck with it, everything should go smoothly.
Old 10-12-2008, 10:13 PM
Man from mars's Avatar
Man from mars Man from mars is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab S
Trim Level: SLT Sport
Color: Graphite Metallic
Rep:15
Man from mars is on a distinguished road
03ramhemi has it right just make sure you disconnect the battery so you don't cause a power spike when diconnecting and reconnecting the wire harness on the alternator. Apower spike can cause a diode to fail.
Old 10-12-2008, 11:35 PM
07HEMI's Avatar
07HEMI 07HEMI is offline
Vehicle: 2007 1500 4x4
Trim Level: SLT Big Horn
Color: Brilliant Black Pearl
Rep:23
07HEMI is on a distinguished road
How did the swap out go ?
