Just anther Synth oil ? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 10-19-2008, 10:37 AM
grey06hemi4x4's Avatar
grey06hemi4x4 grey06hemi4x4 is offline
Vehicle: 2006 1500 sport quad cab 4x4
Trim Level: sport
Color: grey
grey06hemi4x4 is on a distinguished road
It doesnt effect anything and its a lot better for your truck, the engine builders say you can go 5000+ with no oil change. I switched to synthetic because i had a boxing ring to pull on weekends and its just a better oil all around
Old 10-24-2008, 03:49 PM
EvilTwin
Switching to full synthetic isnt a problem at all, it wont affect the warranty. The only thing about it is pick one or the other. If you go to synthetic you cant go back. Also, you should probably switch gradually. Next change, use blend and then after that use the full synth.
Old 10-24-2008, 04:45 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
It doesn't hurt a thing to switch from regular to synthetic. Mixing is actually a very bad thing, ask any good mechanic!
Old 10-24-2008, 05:10 PM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
In the USA most synthetics are a mineral base Group III. If they were still Group IV it would not be a good ideal to routinely keep going back and forth although it would not cause any damage.
Old 01-16-2009, 01:23 AM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
Won't hurt a thing. I use Mopar 5W20 synthetic (mainly becuase that is what my dealership uses), but it does not break down near as fast as conventional oils. However, that does not mean not changing the oil at the recommended service intervals. It is a little bit pricier, but, to me, worth it, and no, it won't affect your warranty.
Old 02-08-2009, 09:26 AM
Eric the Ricer
How many quarts of oil do I need? I left my manual at work the night I bought my truck, can't seem to find the damn thing anywhere!
Old 02-17-2009, 10:24 AM
Heminator's Avatar
Heminator Heminator is offline
Gender: Not Specified
Vehicle: 2005 Dodge Hemi QC
Color: Almond Metallic
Rep:35
Heminator is on a distinguished road
Send a message via AIM to Heminator Send a message via Yahoo to Heminator
I am using the SSO Amsoil with dual filters and change oil every 30 to 35,000 miles with no problems. I have 77,000 miles on our 05 Hemi and it uses less than an pint between changes.
Success is not final, failure is not fatal: it is the courage to continue that counts".
Old 04-16-2009, 10:57 PM
Marcelo's Avatar
Marcelo Marcelo is offline
Vehicle: 2005 5.7L HEMI
Trim Level: SLT Quad Cab 4WD
Color: Flame red
Rep:34
Marcelo is on a distinguished road
Originally Posted by Zonestar View Post
.... If you have the 5.7 HEMI use 5W20 motor oil.
I wonder if oil viscosity should be the same in hot weather ... Owners manual doesn't tell a word about it. My RAM always used Castrol Syntec Blend 5W20, but I don't really know if these everlasting summer I live and drive in should make me go up in viscosity
Old 07-10-2009, 05:15 AM
JDTDBD JDTDBD is offline
Vehicle: 2002 Dodge Ram
Color: Charcol
Rep:12
JDTDBD is on a distinguished road
Send a message via AIM to JDTDBD
Default Royal Purple Synthetic Oils
Royal Purple is the oil I use. They ran a test on a stock vehicle and changed out the oil, Diffs and tranny fluids to their brand of synthetic fluids and Held loer operating temps and picked up gains of 5HP to the wheels! It is a little more expensive then other Synthetic brands but this is one of those "you get what you pay" for products.
http://www.royalpurple.com/index.html
