Old 10-27-2008, 07:02 PM
chrishatcher
Default HELP Right carb for 84 Ram
A friend has an 84 w/ 360 and thermoquad. What years are these carbs interchangeable? Can we use a late 80's or an earlier one?
Thanx!
Old 10-28-2008, 10:25 AM
psychomekanik
Thanx!
I can't tell you exactly what years would interchange. But, if you're going to a junkyard look, just make sure yours has the same type of choke, and the linkage is the same. What's the reason for replacement instead of rebuild?? If you go to a junkyard to find one, it's gonna need rebuit also.
