06 ram 1500 5.7 Hemi - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 11-11-2008, 09:09 PM
tweety
Default 06 ram 1500 5.7 Hemi
I noticed the other day when sitting in traffic my tach drops to about 200 rpms. no noticable change in the running of the motor miss or stumbling...
So the question is... do any of you experience or have experienced this and or is it a problem...? On older model vehicle I would say something is up but I am not familiar with this gen Dodge.
Terry
Old 11-11-2008, 09:48 PM
07HEMI's Avatar
07HEMI 07HEMI is offline
Vehicle: 2007 1500 4x4
Trim Level: SLT Big Horn
Color: Brilliant Black Pearl
Rep:23
07HEMI is on a distinguished road
I have a 07 5.7 does the same thing
Old 11-11-2008, 10:20 PM
tweety
ok whew, I think...,
I just bought it fri used (43K on it) so... it kinda took me by suprise today when I looked down and saw the tach drop out. Has yours done it since you owned it? have you had your 07' since new? No issues or have you had it looked at from tach drop issue?
Old 11-11-2008, 11:14 PM
peshields peshields is offline
Vehicle: 2002 Dodge Ram 1500 QC
Rep:14
peshields is on a distinguished road
sitting as in at a constant speed? or just chillin at 0 mph? could be the MDS kicking over.
Old 11-11-2008, 11:47 PM
tweety
yes, sitting at 0 mph. mds does it work at idle? i thought it was just under motion.. light cruising and low/light load. like i said not familiar with new gen and the gizmos that we have today.
Old 11-11-2008, 11:55 PM
psychomekanik
Are you sure it's not actually surging. A couple hundred r.p.m.'s might be hard to detect. If it is, Check for vacuum leaks, then scan for codes. If there's throttle control codes you may end up replacing the throttle body, or the accelerator position switch (on the gas pedal) There's no seperate Idle air control on this vehicle. Idle is maintained by an electronic throttle body..
