wheels and tires - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-14-2008, 07:37 PM
hollywood06 hollywood06 is offline
Vehicle: 2006 Dodge Ram
hollywood06 is on a distinguished road
Question wheels and tires
I have a 96 1500 ram 4x4. I'm looking to replace my rims with black steel rims. I am wondering if a 15 inch rim will fit, i currently have the stock 16's. what bolt pattern and backspacing should i be looking for. I am as well wondering if i can run 33's on the stock suspension. i am intending on lifting my truck just not till next year. I am in need of new tires soon and i have a set 33x10.5x15 sitting out back i would like to use. if 33's would be expected to fit but rub how bad of a rub would i be looking at, or is there a particular spacer height i could use and clear 33's. if there is a spacer height to accommodate my needs who makes them. one last question the 33's i have are 10.5 wide when it would be time to replace them i would prefer a 12.5 width how wide of a rim should i get.
Thanx in advance
Hollywood96
Old 11-15-2008, 08:24 AM
grey06hemi4x4's Avatar
grey06hemi4x4 grey06hemi4x4 is offline
Vehicle: 2006 1500 sport quad cab 4x4
Trim Level: sport
Color: grey
grey06hemi4x4 is on a distinguished road
1-well how many bolts do you have now? cause you need to match them up
2-i went up to a 33 on my 06 but what i did was put the rim on the front then cut out a piece of cardboard to fit on the rim and that was an overall 33.50'' to see where the tire could rub it wont show all but you will get a good idea also you can cut some of the things it rubs to make it fit
3-i have a 17x9 rim with a 33x10.5
go to 4wd.com those guys can help i got my rims there
Old 11-15-2008, 09:23 PM
Why does it seam when yoy try to include all the info you always forget a detail. it's a 5 lug pattern.
hollywood06
