Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
United Radio
Old 11-15-2008, 02:35 PM
tweety
Default HELP!!!! p0406 issues
06 ram 5.7
ok, got a trouble code and symptoms stalling fluxuation idle ... So, I changed the EGR valve. No problem 4 bolts and a connector.. Uh ohhhhh, NOW it wants to really surge and not idle at all. Can someone help me? Do I reinstall the other old EGR valve? disconected battery and reconnected per dealer tech (let puter go to sleep) ummm didn't fix it either..
Old 11-15-2008, 03:12 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Hello and welcome!
I am really sorry I don't have an answer for you but I didn't want to think you were being ignored! I hope someone here does have help for you! Glad to have you here, post us some pictures of your truck!
I just found this on the net:
The P0406 sets when the EGR position sensor's signal return is the same as or higher then reference voltage. Without doing the actual tests on the circuit; I would say that the EGR position sensor is likely at fault. I’ve had to replace a number of valve/sensor assemblies for this reason.
As for an extended emissions warranty, call the dealer with your VIN # and mileage and they’ll tell you whether there is any coverage for this.
Maybe this will help?
Old 11-15-2008, 04:12 PM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
I not positive about this but I thought emission parts were warranty for 70k miles or 7 years because of federal guidelines.
Old 11-15-2008, 05:44 PM
tweety
well, here's some FYI for all.... make sure to check the EGR pipe where it goes into the back of the intake.... mmmmm hmmm when I went to put the old EGR back in I notice that the cheap clip that holds the pipe in the back of the intake let the pipe fall out.. So, far as I can tell THAT was my issue of why it wouldn't run.. OLD SCHOOL vacuum leak I call it. Seems to run fine now.
Old 08-01-2009, 06:14 PM
centerpoint04 centerpoint04 is offline
Vehicle: 2006 Dodge Ram Quad Cab 2wd
Trim Level: Big Horn Addition
centerpoint04 is on a distinguished road
Originally Posted by tweety View Post
06 ram 5.7
Hi there, I also have an 06 hemi with 80k miles and now have the same trouble code but no symptoms yet. I still want to replace the EGR Sensor before I start with the symptoms. Where did u get the part, and was it easy to install? Where is the sensor located?
Thanks for any help
Old 09-03-2010, 04:13 PM
Digipenguin's Avatar
Digipenguin Digipenguin is offline
Gender: Not Specified
Vehicle: 2006 Ram 4WD
Trim Level: SLT Sport
Rep:81
Digipenguin will become famous soon enough
I know this post is old but I wanted to answer the question for anyone else who has this prob.
The EGR is located at the front of the engine. It is accessed from the top of the engine. It is on the left hand side as you look at the motor from the front. It is just to the left and below the alternator. I thought it was the coil when I first looked at it because that was where the coil was on my 318. HTH.
It was on fire when I got here.
