Old 11-21-2008, 01:38 PM
Mikey71
Default Poor Heat and AC Airflow
This issue is with both heat and AC equally. When I turn the fan speeds up or down I can hear the fan going and blowing at the appropriate speeds. It also will switch to all the different areas without issue. Unfortunately though, the top airflow I can get is roughly equal to the lowest setting (if everything was working ok). I brought it in to the dealer and they think it is a/the doors inside, but estimate the cost at roughly $1000 due to 8 hours labor. Please say there is an easier and/or cheaper way? Is there an air filter somewhere that I can easily get to? Is there an intake to the system that I can check out?
I am not a mechanic to say the least, but know enough to be able to follow instructions on what to try. I friend and I tried to take the dash apart and had it in a million pieces, but couldn't figure out how to get to and or check out where those doors may be in that black unit behind the glove box.
Old 11-21-2008, 02:17 PM
racer53
not sure of what year and make so there may b different answers but to start i would pull the blower down hold the motor part of it and turn it the squirrel cage should be spinning xtremely fast and feel like its gonna twist out your hand ive delt with blowers slowin down like a fuel pump does when it starts to go out its rare but ive delt wiht it
what year and make truck is that anyway
mike
Old 11-22-2008, 10:03 AM
Mikey71
Oh yeah, it is an 03 Dodge Ram.
To get to the blower and cage, would I have to take the dash apart again or is it something I could get to either thru the glove box or from underneath it? It is extremely frustrating being here in Canada and having to let the engine run for an extra 10 or so minutes to clear the windshield of ice/frost.
Old 11-23-2008, 07:53 AM
grey06hemi4x4's Avatar
grey06hemi4x4 grey06hemi4x4 is offline
Vehicle: 2006 1500 sport quad cab 4x4
Trim Level: sport
Color: grey
grey06hemi4x4 is on a distinguished road
i had this probelms with my truck and camaro when i was living in fl they pull the blower out and it was blocked up with leaves, dont kno how that happens
Old 11-23-2008, 09:36 AM
racer53
i swear i pulled a blower down that was makin noise it sounded like the cage was broke i got it down and it was full of chicken wings like somone ate them and threw em down the defroster of somethin gross
mike
Old 11-23-2008, 04:15 PM
Mikey71
So how do I get to the blower on my 03 Ram? Can I do it myself or is it a dealer thing?
Old 12-05-2008, 12:01 AM
CrazyCooter88
Pick you up a tech manual from your local parts store, it will show you a step by step how to pull it down and put it back together and it will have pics there to show you. Getting to the motor is easy because its on the firewall under the hood if I remember right. A/C and heater work are very easy to fix and work on and to tell the truth, the tech that would have work on your truck would be paid flat rate (which means if dodge says this job takes 5 hours then that is how many hrs he gets paid no matter how long it take) and probly would have took about a hour to a half hour to fix, but you would still pay the full time.
Old 12-05-2008, 11:30 AM
racer53
the o3 blower is right under the passenger side of the dash look up from the floormat and its right there
mike
