Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 12-02-2008, 10:45 PM
anthony8797
Exclamation I need help with a 94 Dodge Ram diesel
someone please help me. i am going crazy i bought a 94 dodge ram 2500 4x4 5 speed diesel.. it has been sitting for 4 years.. nothing gelled up in the fuel system luckily i cant get it to fire on the new diesel fuel i put in it.. i bleed the system up to the injection pump but i cant get much fuel from the injection pump to the injectors.. and when i do it is not much.. some one please help me and tell me what i can do.. i only know gas engines i am not to familiar with diesel....
Old 12-03-2008, 12:39 AM
Unbridled's Avatar
Unbridled Unbridled is offline
Vehicle: 2001 Dodge Ram 1500 4x4 w/318
Trim Level: Ext. cab Laramie SLT
Color: White w/ graphics
Rep:19
Unbridled is on a distinguished road
Welcome to the forum. Unfortunately, I can't help you. I'm like you and only know gasoline engines.
Old 12-03-2008, 02:10 AM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
WELCOME to the ForumZ!
Sorry for you issue ... I know diesel engine (my Caliber is a diesel) but I don't know RAM , so I guess I can't help you ...
Anyway I'm sure someone else here will. Enjoy your stay!
Old 12-03-2008, 07:55 AM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 07 Ram Mega Cab 4x4
Color: Black metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
have you checked your rail pressure up to the injector pump ?
you might have an air leak (vaccum) in the system some where cosing not enough fuel pressure to build.
call your local dealer ask for the best diesel mech there and explain to them whats going on.
if not call a cummins dealer they will know for sure.
also make sure your fuel filter is on tight that will also cause no fuel to the injectors
good-luck
Old 01-24-2010, 09:49 PM
kiwi72 kiwi72 is offline
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
kiwi72 is on a distinguished road
check the screen in in bowl next to lift pump maybe blocked
Old 01-24-2010, 10:44 PM
Not sure on the Cummins . I mess with heavy equipment at my work and they have whats known as a lift pump . Not sure if you have one . But basicallly it's a small mechanical pump for the injection pump .
Old 01-25-2010, 02:10 AM
Rep:1885
Since it's been sitting for so long and you know you have fuel to the injector pump I'd suspect the injector pump and/or injectors.
Old 02-12-2010, 05:07 PM
wmonroe's Avatar
wmonroe wmonroe is offline
Vehicle: 2007 Dodge Ram 2500
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
wmonroe is on a distinguished road
If you haven't done so already I would change the fuel filter, and was already mentioned change the pre screen that is beside the fuel filter. When you remove the pre screen there is a black plastic piece like a hockey puck that is the fuel heater, take it out and put back together without it. The fuel heater can get small cracks in it that let air in.
If none of that fixes your problem I would replace the return fuel line. It dry rots, cracks and lets air in and causes a hard/no start condition. It won't leak fuel but it will let air in. After that if no go I would pull the overflow valve out and stretch the spring to about 5/8" and if that fixes the problem get a new overflow valve.
The lift pump and injection pump on the 94-98 12 valves were very durable units, not saying they never had any trouble, just not the first place I would look.
And for the record my last truck developed a crack in the fuel heater causing a no start condition, after removing the fuel heater the truck ran great.
2007 2500 ETH DEG 4x4 285-75-17 Nittos, 3250 dual disk and extra fuel
2005 Wrangler Willys Edition
Old 02-12-2010, 05:08 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hello and welcome
Old 02-12-2010, 05:54 PM
Snowman's Avatar
Snowman Snowman is offline
Vehicle: 2010 Cummins 3500 Crew cab
Color: White/two tone
Rep:34
Snowman is on a distinguished road
If fuel is reaching the injecter pump then you MIGHT need a new injection pump. Check with local diesel tech.
