MOPAR DECALS
Old 12-17-2008, 08:34 PM
DevilDoc19
Default Noise when letting off of accelerator
It sounds like it is coming from the driveshaft U-joint area but only when letting off the gas or when not accelerating. Kind of a metal whining sound I guess, maybe metal on metal. Anything out there that is common for a 2001 Dodge Ram 1500 5.9L 4x4? Any ideas at all will be greatly appreciated, I like to do things myself on the truck but this one might be out of my league if it is too much, but figuring it out is the first step.
Old 12-18-2008, 12:11 AM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
ok first thing to diagnosis your problem, is your truck a short bed or long bed because the long beds have a carrier bearing and can cause the noise second check to see if your driveshaft u-joint clamps are tight to the rear end second if you can kinda pin point where your problem persist like safely rolling 15 mph and letting off the accelerator having your head out the door like i said safely lol dont want any mishaps but all in all be sure it isnt your rear-end going out.
Old 12-18-2008, 12:44 AM
Yeah, if you have a long bed, check the carrier bearing. The other potential is the output shaft bearing on the transmission or the differential yoke bearing.
Heaven forbid it's inner axle bearings because if you can hear them, it's too late for the bearing race on the differential tube casting. ouch...
Old 12-18-2008, 12:49 AM
you read my mind maddog lol
Old 12-18-2008, 12:55 AM
I'm good at that...just don't know my own mind.
