Heater problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 12-18-2008, 09:04 PM
odj22sailor@gmail.com
Default Heater problems
I have preformed a radiator flush, changed the thermostate, and water pump.
I am no longer getting heat in the cab. Any thoughts?
I am freezing it is very cold in the morning please help someone.....
Dave
Old 12-18-2008, 10:08 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
What year truck, engine, ect>>>????????
Old 12-18-2008, 10:09 PM
Rep:62
Is there air blowing inside the cab, just not hot?
Old 12-18-2008, 11:35 PM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 2015 Ram 1500 4x4
Color: Silver metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
yes Dave we more info about yur trk
the only one here that is phsycic or phsycotic is (bluejet)
Old 12-22-2008, 05:25 PM
phatony101090
i have the same propblem i have a 01 1500 my air is blowing but there is no heat at all its just blowing pure normal temp air idk what to do either
Old 12-23-2008, 11:43 AM
hh53helomech hh53helomech is offline
Vehicle: 2014 Ram 1500 Express
Trim Level: st Exprexx
Color: flame red
Rep:27
hh53helomech is on a distinguished road
Had the same problem on my 07 Ram 1500. Took it to the dealer and they found the recurculating air door for the A/C and heater had come off letting the cold air blow in the cab.
Old 12-23-2008, 05:22 PM
bobczyk bobczyk is offline
Vehicle: 1998 dodge 4x4
Trim Level: larami
Color: blue and silver
bobczyk is on a distinguished road
Did the problem occur after the radiator flush, thermostat, and water pump or before? Cooling system could be air-locked.
98 dodge 4x4 5.2
Old 12-23-2008, 09:22 PM
Springfield Don
I joined this forum because I am looking for a solution to the same problem. 2002 1500 blows cold air. I just had the heater core replaced and still get very little heat. The radiator and thermostate was also recently replaced. A lot of money spent and very little heat.
Old 01-14-2009, 12:53 PM
offlimits4wd
New here also. I have a 03 Ram 1500 4.7 with little to no heat also. Replaced all normal stuff. Radiator, water pump, thermostat and removed heater core and that looked fine. Didn't replace it because nobody had one in stock. It wasn't clogged and was not leaking. Both hoses going into heater core are at same temp. Removed new water pump and visualy checked it and it seems fine. Removed dash and checked blend doors and no broken or cracked doors. Should be no air pockets. We vac filled rad last night.
Any Ideas would be great.
Oh another wierd thing the temp gauge sits at half. If we hold idle up to 3k it comes down to 1/4 within seconds.
Thanks. Bryan
Old 01-14-2009, 05:00 PM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Thanks. Bryan
Sorry I don't have an answer for you, but I see you are new here, so WELCOME ! You had better to open a New Thread so all the members could see it and give you some help. Don't forget to go on Newbie Checkin too and introduce yourself! Thanks
