Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 12-28-2008, 03:54 AM
03ramhemi's Avatar
03ramhemi 03ramhemi is offline
Vehicle: 2003 Dodge Ram 1500 QC Hemi
Color: 2 tone, black with silver
Rep:14
03ramhemi is on a distinguished road
Default oil change
alright everyone, i kno everyone has prefrences on motor oil and how long they wait and such. my question to y'all is, im in need of and oil change soon, i do my own and i use synthetic, the last brand i used was quakerstate Q-horsepower full synthetic and not to sure on the wait with a mopar filter. what weight and viscocity would you use? i have a 2003 qc Hemi 2wd 82,xxx miles and do no towing but do have a superchips programmer and hate to say it but kinda have a lead foot. my comp. on the ceiling says i get a 12.5 mpg avg. everywhere with a tonneau. let me kno what you think and thank you.
Old 12-28-2008, 05:53 AM
Aggie 5.7's Avatar
Aggie 5.7 Aggie 5.7 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Lone Star 5.7
Rep:12
Aggie 5.7 is on a distinguished road
Does your truck burn oil? If so, I'd go with a high mileage oil (with 80k, I doubt you would, but it wouldn't be unusual if you did.)
Also, check your manual, it will tell you the BEST oil weight you can run... I know when Dodge started their "4-cylinder shutoff" they started recommending the use of 5w-20. I'm not sure if your truck uses that, but if it does, then I'd go with the 5w-20 so you don't get any engine problems.
As for brand, as long as you're going full synthetic, you really can't go wrong. Certain enthusiasts will swear by one brand name or the other, but for the most part, they're all pretty similar. I personally use Mobil 1 and/or Royal purple. I know they're a bit costly, but since I drive it like I stole it, I think I can justify the cost.
Hope this helps!
Old 12-28-2008, 07:45 AM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
The recommended viscosity is 5W30 for your engine if your engine is not equipped with MDS.
Old 12-28-2008, 08:42 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Check this out. It's pretty much everything you every wanted (or didn't want) to know about motor oil. Make your own informed decision.
The Motor Oil Bible
Good Luck
Exco
Bill
Old 12-29-2008, 09:11 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
I used 5W-30 in my 03 ram 5.7, i sold it with 120,000 miles on it and I used Mobil-1 in it sense I bought it new. In my 08 I use RP with a K&N filter.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 12-30-2008, 01:15 AM
03ramhemi's Avatar
Rep:14
thanx everyone, no my truck doesnt burn oil, and dont have mds, but ya i believe i used 5w30 last time and i'll just stick with it, its been around 5k or alil more since last change, and i think i'll stay with the same brand as well, dont kno if itll effect anything but it wouldnt hurt to stick with the same stuff. thanx everyone
Old 12-30-2008, 01:25 AM
Rep:100
Well, If you have had good service with quakerstate then stick with it, But there are much better oil filters then Mopar, Mobil-1 or K&N are much better filters.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 12-30-2008, 02:34 AM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
with every oil change i do, i use mobil 1 full synthetic 10w30 and add a bottle or lucas additive to make sure its sticky but the thing you have to watch out for when doing the oil changes is the conditioners and other additives they add in the oil like for instance i work for a shop and we use kendall oil and with every viscosity you want from 0-20 to a high mileage the only problem is, i know it may sound wierd but it is true when for long period of time using one brand then switching to another can cause problems ive seen a ram that used only thatq horse power for a long time and then had us for the last 3 oil changes use a regular 5w20 which is what allot of rams take then started causing a blow-by because the valve guides were taking a crap but just be careful in what you use try if you can yourself taking like a drill bit against metal and use a few different oils you can see the difference in the lubricant but good luck and its not dumb asking those questions, oh and i prefer fram filters the only difference from it to a k&n is you tightn the k&n with a wrench and your paying more and i go 6k miles to every oil change and have gone roughly little over 7k miles but post by the way
